Transfer case oil
Results 1 to 7 of 7
2008-2013 Cadillac CTS Performance Mods Discussion, Transfer case oil in Cadillac CTS Second Generation Forum - 2008-2013; Any recommendations for what oil to use in the transfer case on an 08 CTS4 DI??...
    Badab!nG is offline Cadillac Owners Member
    Automobile(s): 2008 CTS4
    Jul 2012
    Upstate Nuh Yawk
    40
    16
    Transfer case oil
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    8,855
    Re: Transfer case oil
    Rear Drive Module and Transfer Case
    (All-Wheel Drive) Transfer Case Fluid (GM Part No. U.S. 88861950, in Canada 88861951).
    From the 2010 Owners Manual. It's in there, easy to find.
    00 ss is offline Cadillac Owners Fanatic
    Feb 2012
    Colorado
    457
    Amsoil does not have a fluid that they say is a suitable substitute which leads me to believe the only place to get the right fluid is the dealer. Until very recently, I had to get the T-case fluid for our Grand Cherokee (NV247) at the Jeep dealer as well. I would not recommend using any fluid that is not specifically made for your T-case. With the complicated T-cases these days, using the wrong fluid will probably impair its ability to transfer the right amount of power to the rear/front wheels.
    tinman's Avatar
    Jul 2006
    8,855
    Quote Originally Posted by 00 ss View Post
    ...and might void your warranty.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,208
    The front/rear power split is determined by the ratio of the planetary gears in the center differential gear set in the transfer case and does not vary.
    Don't mess with Binky Bear!
    Feb 2012
    Colorado
    457
    Everything I've read says that the T-case in our cars is a torque vectoring case with a viscous coupling. Meaning it can vary the amount of power sent to the front wheels vs the rear wheels. The "gear ratio" better be 1:1 front to rear or the font and rear wheels won't spin the same speed. It's not supposed to be just an open center differential.
    Jul 2012
    Upstate Nuh Yawk
    40
    16
    I did get my t-case oil from the dealer. After not finding a suitable Amsoil substitute.
  10. Remove Advertisements
