The Plenum Iceolator for the 3.6 DI!!
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
2008-2013 Cadillac CTS Performance Mods Discussion, The Plenum Iceolator for the 3.6 DI!! in Cadillac CTS Second Generation Forum - 2008-2013; No real power gains, but reduces the false knck so the ECU is not pulling timing so often. $129 plus ...
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    $129 plus $10 S&H.
    Wag-O-Neer is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-4 Wagon Premium 3.6 w/FE2
    Dec 2011
    Maryland
    214
    Re: The Plenum Iceolator for the 3.6 DI!!
    Very cool. If anyone has looked at my ECM timing logs from my Trifecta tune thread, you can see exactly how finicky the KR is in this car. This should help reduce the amount of timing retardation at WOT in the upper rev-range, I would think.
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    Let me know if you want to try one...I'll send one out to you.
    Michael_atDell's Avatar
    Michael_atDell is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS 3.6L DI AWD
    May 2011
    Austin, TX
    37
    404
    Is this different than the upper intake gasket? Certainly looks different...
    krazienluv10 is offline Cadillac Owners Member
    Nov 2011
    59
    yes it is thicker and provides better air distribution inside the plenum...
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    May 2011
    Austin, TX
    37
    404
    The picture does not look anything like the one I installed... I'm confused...
    Nov 2011
    59
    maybe u installed the intake manifold gasket spacer...the one in the pic is a plenum spacer, both are worth the purchase!
    May 2011
    Austin, TX
    37
    404
    Yes, I did... Where does this one go?
    Nov 2011
    59
    this is from the camaro forum....youll get the idea
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    Thanks Krazien!
    No real power gains, but it does decrease the amount of spark knock and helps reduce the timing pulled by the ECU.
    May 2011
    Austin, TX
    37
    404
    Even if you already have the intake isolated already installed?
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    OK, we sepnet 1/2day straight on the dyno and here is what we found:
    Plenum spacer showed no gains at all, and on this car running 93 octaine no noticeable reduction in spark knock (earlier tests showed some), so not really worth the $$ as far as price vs gains. We made a bunch of these and we did see reduced spark knock/timing pulled in earlier tests where the grade of fuel was not verified.
    The 1" showed 1* F cooler (not enough to make a difference(, but 2-3 rwtq gains at the low rpm range.....but here was the shocker, 14 rwhp LOSS above 5800 RPM ( I will post graphs).....so even though the demand is great from another companies posts, we found driveability far better with the 3/8" original. Again, we made a bunch of these due to the demand, but the fitment of the higher position the IM sits and the small tq gains, this is not worth it either unless your set on it.
    Again, a solid 20 plus rwhp & 25-28 rwtq from the 3/8" alone (with 93 octaine) is an unreal gain from the low price.
    To order, call direct: 941-721-1826
  16. #14
    Panzer Leader's Avatar
    Panzer Leader is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS 3.6 V6 RWD Performance Sedan
    Jun 2012
    Mandeville, Louisiana
    588
    Interesting, this was tested out over on the Pontiac Forum as well. They reported crisper shifting patterns and better acceleration. Some where adding this, changing out the cams, adding CAI and modding the exhaust. Then doing the new tune that is out. They areclaiming that the spacer reduces intake air temps. All that said is this available for the 3.0 liter? Do you recommend changing to a CAI?
  17. #15
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    Available for several models of the GM V6, Reduces the IM temp30-33*F.
    Yes, I would go with a CAI for sure.
  18. Remove Advertisements
