Lock pick for CTS
Results 1 to 13 of 13
2008-2013 Cadillac CTS Performance Mods Discussion, Lock pick for CTS in Cadillac CTS Second Generation Forum - 2008-2013; Is there a lock pic mod for the nav display. This enables the nav unit to be programmed while driving ...
    zek4964 is offline Cadillac Owners Fanatic
    Automobile(s): 08 cts 68k, 07 STS-V 15K, 97 Sts 160k
    Jun 2010
    Rochelle IL
    302
    Lock pick for CTS
    Is there a lock pic mod for the nav display. This enables the nav unit to be programmed while driving and be able to watch a DVD while going down the road. Is there one for the CTS? I know there is one for the STS.
    Jagillac's Avatar
    Jagillac is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Coupe
    Oct 2011
    29
    281
    Quote Originally Posted by zek4964
    I believe there is one. I saw a video on YouTube showing the instal.
    kingtj is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS4 Coupe, Premium edition
    Dec 2011
    Poolesville, MD
    234
    Re: Lock pick for CTS
    Yes, you can use the one made by PAC:
    http://www.pac-audio.com/productDeta...&CategoryID=34
    The "lockpick" branded one in some of those older YouTube videos is no longer in production, though.
    Quote Originally Posted by zek4964 View Post
  5. #4
    Jun 2010
    Rochelle IL
    302
    The Pac does not say it unlocks the DVD feature just blue tooth and NAV.
  6. #5
    Rdecrane5 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Cadillac CTS Coupe RWD
    Mar 2012
    35
    116
    PAC unlocks the DVD also.
  7. #6
    larryb is offline Cadillac Owners Member
    Automobile(s): CTS wagon
    Mar 2012
    49
    9
    Yes looks like it will unlock nav. I am interested in this product as well. However the install looks like it used a switch which is not used for heated steering wheel, I emailed them if this module can still be installed, waiting to hear back. I haven't found any other modules that will work with late model cts 2011-12
  8. #7
    Jun 2010
    Rochelle IL
    302
    It would be nice to hear from you when you do here back from them on that issue.
  9. #8
    Mar 2012
    49
    9
    Yes they say unlocks everything that "locks' when car put in drive, so yes should unlock dvd, sound like install on 2011 would be similar to the Vs using mirrow switch, just waiting for last confirmation and I will order NU-CTS2, also looking for input on how hard to install this..
  10. #9
    Dec 2011
    Poolesville, MD
    234
    I can confirm this for you. I have a 2011 and installed the NU-CTS2 already. This is exactly how it works ... You press the "up arrow" on the mirror directional adjustment twice (once to activate the feature and the second time to acknowledge it when the DIC displays a message asking you to confirm it). The install was pretty straightforward. I didn't have to change any of the default DIP switches found on the box itself. They shipped it properly configured for me. The only problem I had was prying the wood trim pieces off that must be removed to get the stereo out of the dash. At least on my car, those suckers were on TIGHT and even with a couple of trim tools, I managed to gouge a chip out of the corner of the piece on the driver's side of the shifter.
    Quote Originally Posted by larryb View Post
  11. #10
    Mar 2012
    49
    9
    Could U give more info on install or where U found instructions on how to remove radio?
  12. #11
    Wag-O-Neer is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-4 Wagon Premium 3.6 w/FE2
    Dec 2011
    Maryland
    214
    Seems pretty straight forward
    http://www.youtube.com/watch?v=Oe1P2wNdBQM
  13. #12
    Mar 2012
    49
    9
    great thanks, looks easy , let U know how it works
  14. #13
    Mar 2012
    49
    9
    just installed and was straighforward, careful with trim but used plastic trim tool and worked fine, unlock works great using mirrow button, took a bit to get both mirror lights off though
  15. Remove Advertisements
