Optima Yellow Top Installed
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Like Tree1Likes
2008-2013 Cadillac CTS Performance Mods Discussion, Optima Yellow Top Installed in Cadillac CTS Second Generation Forum - 2008-2013; Was in Batteries Plus and they just happened to have the correct model in stock, so I bought it. I've ...
    Michael_atDell's Avatar
    Michael_atDell is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS 3.6L DI AWD
    May 2011
    Austin, TX
    37
    404
    Was in Batteries Plus and they just happened to have the correct model in stock, so I bought it. I've always replaced the stock battery in my cars with Yellow Tops...
    00 ss is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4
    Feb 2012
    Colorado
    457
    Re: Optima Yellow Top Installed
    Why yellow instead of the red top? I have red tops in 2 of my cars.
    May 2011
    Austin, TX
    37
    404
    Red is CCA only, Yellow is CCA and Deep Cycle...
    Feb 2012
    Colorado
    457
    I knew that, but why do you want the deep cycle capabilities in a car? Do you operate the electronics for long periods with the engine off? Do they give you longer battery life than the red tops? I usually get at least 7 years out of the red tops. The main reason I get them is because the won't ever leak. Battery acid will rust out any metal it gets on very quickly. I like the idea for the CTS because the battery is in the rear quarter. If it ever leaked, the rust damage would be extensive.
    May 2011
    Austin, TX
    37
    404
    I usually have lots of electronics, and use the radio with the engine off quite a bit, but yes the non-spill design is another reason I use them.
    Bandit1's Avatar
    Bandit1 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 ATS 3.6 RWD Premium
    Oct 2008
    Ashburn, VA
    495
    Good choice. Plan to do the same this fall. Did you install the #8014-045 D34/78?
    MoFex's Avatar
    MoFex is offline Cadillac Owners Connoisseur
    Automobile(s): 08 White Diamond CTS DI RWD FE2 all options
    Oct 2007
    metro Atlanta
    60
    2,541
    Batteries in my and my wife cars' usually last 3.5 years. I had two exceptions - my very first car 30 something years ago and......the CTS! The former lasted 5+ years (I sold the car after 5 years of ownership) and latter - CTS is 4 years 5 months old. I thought about changing the battery but after trickle charging it a couple of times over last 2 months it seems to be doing well.
    A question - if Optima I think I would go with RedTop. Which model? Do they really last that long? Are they worth the money? I have no experience with Optima whatsoever.....
    Feb 2012
    Colorado
    457
    I've had several batteries leak over the years and the damage the acid does is severe. I think the Optimas are worth it just for the fact that they can't leak. I had one bad optima that lasted less than 1 year, it lost a cell and was replaced under warranty. But the rest have lasted longer than I owned the car I put them in. I have now in my 2000 Camaro SS that's been there for about 7 years and I have one in my 2003 Grand Cherokee that has been there for about 4 years. Previous Optimas have lasted 7+ years. It's really the only battery I buy anymore unless they don't make one for the particular application or if I don't intend to keep it long. Even my old street bike had a gel cell, although not an Optima since they didn't make motorcycle applications.
    sfv41901's Avatar
    sfv41901 is offline Cadillac Owners Connoisseur
    Automobile(s): 08 CTS
    Jan 2009
    Palmdale, Ca
    38
    1,249
    I've been thinking of getting 1 when the batt that's in there now dies.
    reciprocity is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V, 2009 CTS Premium, 2016 ELR
    Jan 2005
    California
    328
    Very cool. I'll probably do the same after my warranty runs out. I figure I might as well let GM replace it if it dies before then.
    Which battery number did you buy? Was there any trick to it or did it bolt right in? Did you use any sort of reserve battery to avoid losing your presets?
    May 2011
    Austin, TX
    37
    404
    D34/78 You have to use the adapter, but it bolts down. It's a little smaller than factory, but stays secure. I did not use any trick, but all my presets remained unchanged.
    MoFex's Avatar
    Oct 2007
    metro Atlanta
    60
    2,541
    Quote Originally Posted by Michael_atDell View Post
    "Home made" adapter or you got something "standard"....
    May 2011
    Austin, TX
    37
    404
    Comes with Optima.
  16. #14
    sfv41901's Avatar
    Jan 2009
    Palmdale, Ca
    38
    1,249
    So this model has a vent line?
  17. #15
    May 2011
    Austin, TX
    37
    404
    Car does, Optima does not.
  18. Remove Advertisements
