Best Cold Air Intake to put on my new CTS Coupe?
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Like Tree2Likes
2008-2013 Cadillac CTS Performance Mods Discussion, Best Cold Air Intake to put on my new CTS Coupe? in Cadillac CTS Second Generation Forum - 2008-2013; So Ive been reading and there seems to be a ton of threads on what intake is the best for ...
    Ryantc911 is offline Cadillac Owners Member
    Mar 2012
    29
    24
    So Ive been reading and there seems to be a ton of threads on what intake is the best for the cts. Alot of these threads seem outdated and I didnt see any particular to the coupe.
    I am shopping for a cold air intake for my new cts coupe and I would love some input on which ones have earned a good reputation out there with you all. I drive alot for my job so increased MPG is my top priority although god knows I would love a little extra HP and throttle response. So what would you guys reccomend? Pros/Cons of each etc.
    All input is tremendously appreciated.
    Wag-O-Neer is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-4 Wagon Premium 3.6 w/FE2
    Dec 2011
    Maryland
    214
    Re: Best Cold Air Intake to put on my new CTS Coupe?
    I'll be following this thread as well. I'm researching CAI's now....
    D3 seems to have the only dyno graph, showing gains. However, the test was done by them, not a customer, so take that for what it's worth. The Volant one is interesting as it's the only one with a snorkel that's placed in the grill area. Then there's the Injen, Airaid, K&N, etc....
    I can't imagine that there's much difference between most of these. It mostly comes down to aesthetics and price, I suppose. Although, the Volant has my eye right now, because of the ram-air affect it has. Still researching....
    loosend and loosend like this.
    Michael_atDell's Avatar
    Michael_atDell is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS 3.6L DI AWD
    May 2011
    Austin, TX
    37
    404
    I'm looking a Volant too...
    MTL_CTS's Avatar
    MTL_CTS is offline Cadillac Owners Fanatic
    Automobile(s): 2011 Cadillac CTS-4 Coupe Raven Black
    Apr 2008
    Montreal, Quebec
    300
    Well, from searching someone can correct me if I'm wrong but I only remember ever seeing one true CAI for the 3.6 and that is the injen CAI (the user Mano4 I think is his name started the thread). The others are "short ram" style intakes which draw air from same location as the stock unit.
    Ryantc911 and Ryantc911 like this.
    Mar 2012
    29
    24
    Quote Originally Posted by MTL_CTS View Post
    Interesting.. Can anyone confirm and or elaborate on this?
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): 16 2.0T Perf, 8spd auto, dp, E85, tune
    Aug 2010
    S FL
    811
    The stock unit pulls in air from in back of the grille, what is called a "cold air intake". This just means that the air is not drawn from under the hood, warmer air heated by the engines heat. I have the KPE intake and it gives a larger square inch filter and a smoother passage of air to the throttle body. It actually is branded "Air raid" on the tube between the filter and the t-b. There is a deeper sound of air being pulled into the engine with this intake, and it appears by the old sotp to add a little more power. The D3 intake is a similar model.
    Dr.Ford is offline Cadillac Owners Member
    Automobile(s): 2012 CTS Coupe
    Nov 2011
    Hollywood, CA
    30
    What year is your "new" CTS coupe? Beware that the intakes for the 2008-2011 3.6L CTS engine will NOT fit the 2012 3.6L engine. I found this out the hard way. On the 2008-2011 3.6L engine the air box assembly is a separate piece from the air intake collar that houses the MAF sensor. The new 2012 coupe's air intake box and MAF sensor is all one piece. So you either have to cut and modify your OEM air box or wait for someone to come out with an intake for the 2012 3.6L application. And I even tried ordering the air intake collar piece with MAF sensor fitting attached from the 2011 CTS, but the MAF sensors are different shapes. Anyone have any better luck finding an intake for the 2012 CTS?
    Mar 2012
    29
    24
    Thank you for sharing. Mine is a 2011.
    May 2011
    Austin, TX
    37
    404
    I wish Vararam made an intake for the CTS... I had one on my Vette and it was by far my favorite ever...
    Aug 2010
    S FL
    811
    Here is a picture of the KPE intake installed in my '11 coupe. Also have the oil catch can in there.
    don27d is offline Cadillac Owners Member
    Automobile(s): 2010 cts wagon 3.6
    Mar 2012
    40
    1
    I got the Volant on my 2010 CTS Wagon. Man it was a pain to install. It doesn't quite line up correctly from the throttle body to the hole on the box for the intake filter. Also installing the RAM air required me to remove (cut) a piece of rubber guard that prevented the ram scoop to go into the grill. But, it does pull cold air from the grill. The stock air box scoop goes straight to the headlight area. With the rubber guard in place, the cold air gets deflected away from the scoop. So it doesn't quite get cold air into the air box. Does anyone have the same issues I have? Mainly things don't quite line up correctly?
    Mistercoffee2's Avatar
    Mistercoffee2 is offline Cadillac Owners Enthusiast
    Mar 2012
    Houston TX
    516
    Quote Originally Posted by mikesul View Post
    NEWBE: What is an "Oil Catch Can" and what is the little filter on the oil filler cap for?
    Had my 2008 CTS for 4 days.
    Mar 2012
    29
    24
    So who has shopped these.. Im still on the fence but leaning towards the volant. Im most worried about increasing my MPG right now because I drive alot for work.
  16. #14
    loosend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DI RWD w/ Prem & Perf Pkgs Blk/Blk FE2
    Nov 2009
    Maryland
    132
    Quote Originally Posted by Wag-O-Neer View Post
    The snorkel is the reason I bought a Volant but I haven't installed it yet. You can also purchase a second snorkel tube that attaches to the bottom of the box as well. It "should" give a ramming effect as vehicle speed increases. I always liked the Vararam for the G8 but our radiator and grill set-up is different.
  17. #15
    Mar 2012
    29
    24
    Would the snorkel being placed in the grill area be more beneficial for someone who is traveling at high speeds on the high way alot compared to the others?
  18. Remove Advertisements
