CTS 08 3.6 DI "Miss fire cylinder 3" only when cold.
Results 1 to 4 of 4
2008-2013 Cadillac CTS Performance Mods Discussion, CTS 08 3.6 DI "Miss fire cylinder 3" only when cold. in Cadillac CTS Second Generation Forum - 2008-2013; I have a 2008 CTS 3.6L DI Premium package. 41,400mi all original parts. It has been running rough on acceleration ...
    rjslik's Avatar
    rjslik is offline Cadillac Owners Member
    Automobile(s): "08" CTS 3.6L DI Premium AWD
    Feb 2012
    I have a 2008 CTS 3.6L DI Premium package. 41,400mi all original parts. It has been running rough on acceleration between 20-45 mph engine light comes on, read code and it says "Miss fire cylinder 3" After it reaches operating temp, it runs fine. Just out of warranty, dealer service says sounds like a coil? I think fouled plug, not sure.
    Anyone have directions to change the plugs/coil do you have to remove the manifold for #3 plug?
    Michael_atDell's Avatar
    Michael_atDell is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS 3.6L DI AWD
    May 2011
    Austin, TX
    37
    404
    Not difficult at all. I just replaced a coil pack for cylinder #4. You do not need to remove the manifold. I replaced all my plugs at the same time. There are a couple of vacuum lines that will make the job easier if removed.
    Good luck!
    jrannis is offline Cadillac Owners Member
    Automobile(s): 2014 SRX
    Jan 2010
    South Florida
    10
    Re: CTS 08 3.6 DI "Miss fire cylinder 3" only when cold.
    Sorry, Noob here. I understand the firing order but how can the cylinder numbers be determined?
    rjslik's Avatar
    Feb 2012
    Changing the Iridium plugs and running GM fuel system cleaner did the job. You DO NOT have to remove the intake manifold as someone on the internet said. The firing order is 1-3-5 on the drivers side and 2-4-6 on the left.
  7. Remove Advertisements
