Steering Wheel Paddle Shifters - Can they be Added? - Page 5
Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 73 of 73
Like Tree8Likes
2008-2013 Cadillac CTS Performance Mods Discussion, Steering Wheel Paddle Shifters - Can they be Added? in Cadillac CTS Second Generation Forum - 2008-2013; FWIW, I suspect the steering wheel shifters can be added if the car has the tap shift ability in the ...
  1. #61
    jcmg8 is offline Cadillac Owners Member
    Automobile(s): none
    Jun 2012
    1
    Re: Steering Wheel Paddle Shifters - Can they be Added?
    FWIW, I suspect the steering wheel shifters can be added if the car has the tap shift ability in the stick. A few of us have done it on our G8's. The post is here.
    Figured I'd join and share I this group ventilated my wallet for a set of s2t paddles.
  2. #62
    Michael_atDell's Avatar
    Michael_atDell is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS 3.6L DI AWD
    May 2011
    Austin, TX
    37
    404
    FYI, I installed my V steering wheel with shift buttons last night on my 2008 DI AWD, sadly the shift buttons do not work for me...
  3. #63
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    I put the V steering wheel on my 2012 coupe and it works fine and to me the paddle shift was worth the price. I switched the trim and controls from my old wheel so it now looks like the stock wheel aside from it's stouter shape and of course the paddles. I'm not sure if I'll go for the actual paddles. I'll drive it like this for a while and then decide.
  5. #64
    ghoward10 is offline Cadillac Owners Member
    Automobile(s): 2009 Cadillac CTS 3.6DI AWD
    Nov 2008
    Bethlehem, PA
    34
    8
    I can confirm as well, I have a 2009 CTS DI AWD, and I had the CTS-V steering wheel installed. The shifters work in the back as long as you are in sport mode. Got it from Luke from Lindsay with the shift knob as well.
  6. #65
    kevmcw is offline Cadillac Owners Member
    Automobile(s): 2009 CTS 3.6DI AWD
    Feb 2012
    Indianapolis, IN
    36
    4
    Just checked with Luke at Lindsay Cadillac. He states that a steering wheel to match my wood trim and leather wheel I currently have, would be 370$. (to upgrade to a shifter button wheel)
    Price is starting to get salty for a non performance upgrade...especially before the paddle extenders are added in.
  7. #66
    X E Ryder's Avatar
    X E Ryder is offline Cadillac Owners Member
    Automobile(s): 2012 CTS Coupe, Premium, Touring
    Mar 2012
    Northern California
    48
    98
    If you do any canyon carving paddles are a must.
    Once you try them there is no going back!
    Go for it.
  8. #67
    Feb 2012
    Indianapolis, IN
    36
    4
    anyone buy these? http://www.ebay.com/itm/251218067260
    same 6061 Aluminum as the S2T extenders, just a different style.....and 125$ cheaper.
  9. #68
    X E Ryder's Avatar
    Mar 2012
    Northern California
    48
    98
    Quote Originally Posted by kevmcw View Post
    Dang! Those are big! Well to me I guess, I have giant hands though and easily reach the buttons with my index fingers.
    Looks like a good solution though.
  10. #69
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,773
    I had them on my 2012 coupe. As a matter of fact, those pictures are of my car. I wasn"t even a little bit happy with them and at the seller's request i sent him those pictures. First, the paddles are way too big. The surfaces on the back are not smoothed and are sharp to the touch. Forget making a turn without hitting either the turn signal stalk or turning the wipers on. They just weren't for me. The seller was very good about taking them back and refunding my money.
  11. #70
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    8,867
    delete post
  12. #71
    Feb 2012
    Indianapolis, IN
    36
    4
    Installed this morning.
    Re-invigorated, rejuvenated, rekindled! LOOOOVE this upgrade.
    I went with the wheel that matched the trim of the previous wheel. Wood isnt an EXACT match...but its close enough...I won't be caring.
    Also went with the ebay paddles...add a little felt/foam inside the connector area (to mimic what the OEM buttons have) and they fit like a glove. The backs are grooved and my fingers fit perfectly. Just a delicate touch is needed. Just flippin fantastic.
    Total cost was: ~470 (370 for the upper trim wheel replacement, 100 for the paddles, 0 for labour, did it myself).
    I would say that the T50 bolt was ridiculous to get loose, but other than that took no time....or talent to do. Just be safe and pull all you airbag fuses after disconnecting the battery. And read the manual on reconnecting the battery! Do your start up procedure correctly.
  13. #72
    zach2011's Avatar
    zach2011 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade Luxury w/Full Platinum Exterior
    Apr 2010
    23
    264
    Just wanted to add my experience:
    I purchased a CTS-V steering wheel with the paddle shifters for my 2008 DI Premium and the shifters do not work on my car. It does have the sport mode so in theory it should have worked, but it does not. I am also getting "Service Stabilitrak", "Stabilitrak Not Ready" and "Stabilitrak Off" messages due to the wheel having a different harness and the extra TC button. It has made my car unsafe to drive. So I will try swapping the harness with the one out of my old wheel but will still have non-functional paddle shifters.
  14. #73
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    i would guess that since the steering wheel with shift control buttons was never offered in 2008 that there's other wiring modifications that would need to be done to get it to work
    if you could get it to work
    i wouldn't advise this mod on a 2008 for this reason
  15. Remove Advertisements
