Cross Drilled & Slotted Brakes Available NOW
Results 1 to 3 of 3
2008-2013 Cadillac CTS Performance Mods Discussion, Cross Drilled & Slotted Brakes Available NOW in Cadillac CTS Second Generation Forum - 2008-2013; That's right you heard it. Finally the cross drilled/slotted rotors are now available for the 2008+ Cadillac CTS. Please note ...
    Dr. Design is offline Banned
    Automobile(s): STS, XLR, STS V-Series, CTS V-Series, XTS....
    Aug 2003
    Design Center
    39
    3,406
    That's right you heard it. Finally the cross drilled/slotted rotors are now available for the 2008+ Cadillac CTS. Please note we have applications for the AWD and RWD models, even the performance suspension models.
    OEM Brake Disc - Basic - Front Cadillac CTS - 08+ $240.00
    OEM Brake Disc - Basic - Rear Cadillac CTS - 08+ $208.00
    OEM Brake Disc - Drilled/Slotted-STD - Front Cadillac CTS - 08+ $420.00
    OEM Brake Disc - Drilled/Slotted-STD - Rear Cadillac CTS - 08+ $360.00
    OEM Brake Disc - Drilled/Slotted-Sport - Front Cadillac CTS - 08+ $420.00
    OEM Brake Disc - Drilled/Slotted-Sport - Rear Cadillac CTS - 08+ $360.00
    OEM Brake Disc - Slotted-STD - Front Cadillac CTS - 08+ $340.00
    OEM Brake Disc - Slotted-STD - Rear Cadillac CTS - 08+ $280.00
    OEM Brake Disc - Slotted-Sport - Front Cadillac CTS - 08+ $340.00
    OEM Brake Disc - Slotted-Sport - Rear Cadillac CTS - 08+ $280.00
    Prices are per axle.
    We also have slotted & OE standard rotors available. Please be sure to check out the performance brake pads also.
    Please let us know if there are any questions.
    Thank you,
    Dr. Design
    D3 Cadillac
    05CTS's Avatar
    05CTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 & 2008 CTS
    Feb 2005
    New Port Richey FL
    38
    1,363
    Re: Cross Drilled & Slotted Brakes Available NOW
    Couple questions.
    Are the rotors casted with the holes or drilled afterwards?
    Do any of the holes go through a vein?
    Are your slots double ball milled?
    Are the rotors heat treated or cryoed?
    Is the hat and veins e-coated or painted?
    If the rotors are drilled after the rotor is made, where did you ever get the idea that drilled rotors are good for racing?
    Aug 2003
    Design Center
    39
    3,406
    Hello,
    No problem. Here are the answers to your questions:
    -All Rotora discs with cross-chamfer drills are machined (not casted)
    -All Rotora discs with cross-chamfer drills are designed not touching the veins
    -All Rotora discs with slots are machined on with single ball end-mill
    -All Rotora discs are heat treated only (no Cryo)
    -All Rotora discs are e-coated (electro-coated). Soon, Rotora will be offering cadmium plated discs for high rust protection from nature weather conditions.
    -In Rotora’s catalogs and all printed materials, we always preach slotted discs are preferred choices when using these discs under extreme use (particularly for tracking purposes). We never recommend drilled discs for competition/track use. Rotora compromised with consumers who demands cross-drill race look with a tracking capability by introducing the drilled/slotted design most of its applications.
    Please let us know if there are any other questions.
    Thank you,
    Dr. Design
    D3 Cadillac
    Quote Originally Posted by 05CTS View Post
    Couple questions.
