Is the D3 intake worth it? - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 61
Like Tree1Likes
2008-2013 Cadillac CTS Performance Mods Discussion, Is the D3 intake worth it? in Cadillac CTS Second Generation Forum - 2008-2013; I'm optimistic w/ this new KPE intake. The group on the CTS-V forum really seemed to enjoy the intake, and ...
  1. #46
    beanjapan's Avatar
    beanjapan is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS
    Apr 2007
    33
    257
    Re: Is the D3 intake worth it?
    I'm optimistic w/ this new KPE intake. The group on the CTS-V forum really seemed to enjoy the intake, and the best part is, at 260 bucks, its not a tough pill to swallow (like the D3 intake). I can't wait till it arrives. I'll be sure to take pictures and do some performance assessments. Hopefully some more ppl will jump onboard on the new intake (to boost the discount to 15%)
  2. #47
    nguyendot is offline Cadillac Owners Fanatic
    Automobile(s): 09 Black CTS 3.6DI D3 intake, Magnaflow Exhaust w/xpipe
    May 2007
    436
    Yeah with the KPE out, I wish I had waited on buying the D3...oh well I got it used half off.
  3. #48
    beanjapan's Avatar
    Apr 2007
    33
    257
    I think you still got a good deal on the D3. After I install the KPE intake on my car, any CTS owners w/ a D3 intake interested in meeting up to compare the two? Let me know, I'm in the Auburn Hills area and I work for GM in Warren.
  5. #49
    Dr. Design is offline Banned
    Automobile(s): STS, XLR, STS V-Series, CTS V-Series, XTS....
    Aug 2003
    Design Center
    39
    3,406
    You got a pretty good deal on a quality system that makes the most HP on the market today. +4HP will add up if you do other performance upgrades.
    Please let us know if you have any questions.
    Thank you,
    Dr. Design
    D3 Cadillac
    Quote Originally Posted by nguyendot View Post
  6. #50
    May 2007
    436
    Quote Originally Posted by Dr. Design View Post
    Thank you,
    Dr. Design
    D3 Cadillac
    I like it, and it looks good under the hood, but I would have rather it been made of thermoplastic (the tube) so it doesn't conduct as much heat. I now contemplate wrapping it in some sort of insulation to prevent the heat soak.
  7. #51
    Aug 2003
    Design Center
    39
    3,406
    Hello,
    We looked into that. The reality of it is the air is moving through at such a rate, it doesn't have time to transfer the heat into the air going into the motor. You can wrap the pipe, but I wouldn't expect any significant improvements or changes.
    Thank you,
    Dr. Design
    D3 Cadillac
  8. #52
    May 2007
    436
    Hello,
    Thank you,
    Dr. Design
    D3 Cadillac
    Is there some sort of grommet that the tube passes through in the heat shield? Mine just... sits in the hole, metal on metal with a huge gap. It doesn't seem... to be a good fit and finish.
  9. #53
    beanjapan's Avatar
    Apr 2007
    33
    257
    I'm not sure if the D3 intake is set up the same as the KPE intake, but the KPE attaches to the stock MAF sensor, and then bolts onto a steel bracket.
  10. #54
    May 2007
    436
    Mine bolts onto the MAF sensor, passes through the hole in the heat shield with no attachment (it literally just sits in the hole, on the thin metal shield).
    I feel there should be a grommett or something to hold the tube...
  11. #55
    Aug 2003
    Design Center
    39
    3,406
    Hello,
    Actually this was designed this way to allow the engine to torque over without putting stress on any joints or grommets. The weight of the aluminum tube and filter can be supported by the reinforced coupler and the high quality t-bolt clamp.
    Please let us know if there are any questions.
    Thank you,
    Dr. Design
    D3 Cadillac
  12. #56
    May 2007
    436
    Hello,
    Thank you,
    Dr. Design
    D3 Cadillac
    Makes sense - that's what the flex section was for in the OEM intake.
    It does concern me however that this will cause the intake to scratch when it torques back down onto the heat shield. Is there a rubber grommet we can put on the inside edge to prevent metal on metal contact?
  13. #57
    woolnerc is offline Cadillac Owners Member
    Automobile(s): 2008 cts-di
    Jan 2011
    8
    Re: Is the D3 intake worth it? At this price maybe
    Well work means I need a pick up once again so my cts-di is being traded back in. This means original air filter and box back in, D3 out. PM me if you interested in almost new cold air system, Black piping and black housing look subtle (all part etc) , sounds great when you give it some throttle for about 150 usd. Postage depending, I'm in Florida.
  14. #58
    Mano4 is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac CTS 3.6 DI
    Jul 2009
    Jacksonville, FL
    18
    I just hate how their isn't a true cold air intake for our cars. The D3 intake is not a true cold air intake it draws air from the engine compatment just as the manufacturers does. I believe the only thing close to a cold air intake we have right now is volant which draws air from the front of the grill i believe; like the infinity m45 k&n filter. The D3 intake looks good though, and has a noticible sound to it.
  15. #59
    Michael_atDell's Avatar
    Michael_atDell is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS 3.6L DI AWD
    May 2011
    Austin, TX
    37
    404
    Quote Originally Posted by woolnerc View Post
    Do you still have your D3 Intake? I can't PM (not enough posts)...
  16. #60
    mblais99 is offline Cadillac Owners Member
    Jan 2012
    thunder bay
    28
    10
    do you still have the intake for sale i don't no how to pm so can you email me at blazer55@hotmail.com thanks
  17. Remove Advertisements
