Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: problem
    avi1777 is offline Cadillac Owners Fanatic
    Automobile(s): 3.6 rwd premium2009 cts
    Jan 2014
    israel
    433
    problem
    hi guys,
    check engine was on a month ago went to the dealer and we changed the pass side catalytic converter.
    light still comes on error no-p0430-00
    it says cc low efficiency bank 2.
    bank 2 is the pass side right?
    what else can it be?
    tnx
    Mar 2010
    Detroit, USA
    12,710
    Re: problem
    Hi avi1777,
    I am sorry to hear the check engine light still comes on your vehicle after your recent repair. Have you had the chance to speak with your dealership about this yet? If you would like us to contact your dealer on your behalf, and assist throughout the process of working with them again, please let us know. We can be reached via private message to further discuss your situation and are more than happy to help anyway that we can.
    Regards,
    Laura M.
    Cadillac Customer Care
    Apr 2014
    44
    Just happened to come across this while waiting for my buddy at kyser cadillac. He said 70% of the time that code will be the catalytic convert.
    He also said it could like 6 other things.
  5. #4
    Jan 2014
    israel
    433
    Re: problem
    the thing is i replaced the faulty converter but it still says its faulty...
    (i bought a new one from the dealership.)
  6. #5
    Apr 2014
    44
    Let's arrow it down a bit.
    Is it running fine?
    Idle good?
    No hesitation?
    If that is all yes could be the PCM.
    If not start cleaning fuel injectors, replace wires etc...will get it just have to run Down through it. Pretty generic code.
  7. #6
    Jan 2014
    israel
    433
    Re: problem
    all good drives normal.last week i did this thing where u put bg straight into the intake manifold,forgot what its called.
    it consume a bit more gas also
  8. #7
    tinman's Avatar
    tinman is online now Cadillac Owners Master
    Jul 2006
    Jacksonville, Florida
    9,495
    Re: problem
    O2 sensor?
  9. #8
    Apr 2014
    44
    Don't use that garbage. Sea foam would have been better.
    Is that the only code?
    Yeah replace the sensor. Hopefully one of 2 things. Fixes it or spits out a another code.
  10. #9
    calif phil is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS
    Jan 2013
    Kansas
    513
    Re: problem
    BG is not garbage. You have it backwards.
  11. #10
    Jan 2014
    israel
    433
    Re: problem
    yes thats the only code,
    can this code mean 2 different things?
    it says catalytic converter.
  12. #11
    tinman's Avatar
    Jul 2006
    9,495
    Re: problem
    What engine do you have? How many miles?
  13. #12
    Jan 2014
    israel
    433
    Re: problem
    3.6 di with 60.000 miles
  14. #13
    Hammerhead100's Avatar
    Hammerhead100 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS Performance Sedan
    Sep 2012
    South Carolina
    160
    Re: problem
    P0430 - OBD-II Trouble Code
    Catalyst Efficiency Below Threshold (Bank 2)
    OBD II Fault Code
    OBD II P0430
    Fault Code Definition
    The Bank 2 Catalytic Converter's emissions reducing efficiency has fallen below the minimum allowable threshold. This efficiency is tracked by a monitoring Oxygen Sensor that is mounted near the outlet of the Catalytic Converter.
    Symptoms
    • Check Engine Light will illuminate
    • In many cases, no abnormal symptoms may be noticed
    • In some cases, there may be a noticeable lack of engine power
    Common Problems That Trigger the P0430 Code
    • Defective Catalytic Converter
    • Internal engine damage resulting in high oil consumption and/or a leaking Head Gasket has damaged the Catalytic Converter
    Common Misdiagnoses
    • Oxygen Sensor(s) are replaced when the real problem is a damaged Catalyst
    • Catalyst is replaced when the real problem is internal engine damage, which is producing elevated emissions levels
    • Catalyst is replaced when a misfiring engine is the real problem
  15. #14
    Jan 2014
    israel
    433
    Re: problem
    no lack of power and i changed the cat,
    maybe its the Oxygen Sensor after all?
    tnx
  16. #15
    Apr 2014
    44
    I assumed you already did replace the o2 sensor. Sorry
  • You may not post replies
