problem - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Like Tree4Likes
2008-2013 Cadillac CTS General Discussion Discussion, problem in Cadillac CTS Second Generation Forum - 2008-2013; its all good halister i appreciate your time. the problem began with 3 bad coils,changed them+all the plugs. then the ...
  1. #16
    avi1777 is offline Cadillac Owners Fanatic
    Automobile(s): 3.6 rwd premium2009 cts
    Jan 2014
    israel
    412
    Re: problem
    then the cat died(at least thats what the dealer claimed,this whole check engine is half a scam to make money any way),
    so u think the o2 sensor can be damaged from a bad cat?
    tnx
  2. #17
    Jan 2014
    israel
    412
    Re: problem
    thanks
  3. #18
    HurstGN is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,541
    Re: problem
    Quote Originally Posted by avi1777 View Post
    tnx
    If you were running excessively rich, the O2 sensor can become fouled, as well as the cat beginning to melt down from too much unburnt fuel in the system. In the old days, if you caught an O2 sensor being fouled early on, a cleaning of the sensor with brake cleaner would sometimes fix it before the contamination became too hard to remove. This from racers that pretty much knew when they fouled the O2 sensor. If it's been more than a week or two, it's probably best to just replace it. I should probably note that when we cleaned them, we were running thin on funds and the O2 sensors were pricey and hard to come by (due to specific application)
    silversport and avi1777 like this.
  5. #19
    Joe77CTS's Avatar
    Joe77CTS is offline Cadillac Owners Member
    Automobile(s): 2008 CTS
    Oct 2016
    Boston MA
    1
    Re: problem
    Hi Guys,
    Wanted to get your opinion on this. So took my 08 DI AWD in due to check engine light and needed oil change. They found that a Coil pack and plug needed to be replaced and that the right catalytic converter needed to be replaced as well. They wanted $1100 to replace the converter and I said no. Do you think the coil pack going bad caused the code for the converter? I have had coil packs go bad in the past (I think a 4 times now) but this is the 1st time they said the converter had to be replaced.
    I have 107K on the car. I was going to replace the cat myself but don't want to waist $450. Appreciate any input!
  6. Remove Advertisements
