Disconnect Center Speaker
Results 1 to 10 of 10
Like Tree4Likes
  • 3 Post By RAB
  • 1 Post By dhendo
2008-2013 Cadillac CTS General Discussion Discussion, Disconnect Center Speaker in Cadillac CTS Second Generation Forum - 2008-2013; What would be the best way to disconnect the center channel? My audio guys forgot to do this when putting ...
    dhendo is offline Cadillac Owners Member
    Automobile(s): 2010 CTS
    Mar 2014
    31
    5
    What would be the best way to disconnect the center channel? My audio guys forgot to do this when putting in new equipment.
    Acdcpsp is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 3.6 LY7
    Feb 2013
    236
    Re: Disconnect Center Speaker
    Removing both A pillars. They are clipped in. Then remove the speaker cover it's all one piece. Start wight the middle and work your way to either end one at a time. then the speaker is held down by two 9mm screws I believe. Then remove the speaker and unhook the connector.
    jamiejam1's Avatar
    jamiejam1 is offline Cadillac Owners Fanatic
    Automobile(s): 2014 CTS COUPE Performance W/Navi
    May 2014
    Miami 305
    212
    Why would you want to do that? BTW I believe that is also the on star speaker! That center gives you Dolby digital, DTS Center channel and Imaging stage and linearity in Digital audio, iPod, XM and DVD... As an Audiophile I would leave it, and if the shop that installed your system says it doesn't do anything, Find another shop.... ...
    Mar 2014
    31
    5
    Quote Originally Posted by jamiejam1 View Post
    Well I do not watch DVD's in my car or listen to any other 5.1 source.. Strictly stereo music that does not require a center channel.. Basically I do not want the shitty noise coming from this channel playing over my nice components.
    I was hoping there was an easy way to do it from the amp instead of taking the dash apart.
    Feb 2013
    236
    Could always take the driver side trunk cover off to get to the factor amp. Find a wiring diagram and point out where the wires go to the center and snip at least one of them.
    Quote Originally Posted by dhendo View Post
    Slee_Stack is offline Cadillac Owners Fanatic
    Automobile(s): 2014 CTS Wagon RWD Premium, Used to own 2005 STS 1SG
    Jan 2010
    GA
    324
    Neither BT nor OnStar use the center channel (according to the shop that just did my install).
    I don't use onstar so I can't confirm though.
    As an FYI, door chimes utilize the front door speakers.
    My center channel is disconnected now. I don't miss it but then I also had a DSP installed making a center channel pointless.
    If just replacing speakers, I'd probably have replaced the center with a matching driver although I would admittedly have wanted a volume control to turn it down. Not so easy with stock Bose.
    RAB's Avatar
    RAB
    RAB is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS Premium AWD Sport Sedan w/FE5 - RadiantSilver|Ebony
    Jun 2007
    Ontario, Canada
    2,108
    With the first 2nd gen CTS I owned (a fully optioned 2008) I discovered that sound wasn't coming out of the center channel speaker most of the time. I discovered the issue while playing a 5.1 DVD-A disc. The problem was traced to poor signal continuity between a couple of connector/plug pins and their audio amplifier mating pins. The problem was resolved at the dealer by replacing/installing new pins on all connectors to the amplifier.
    The best/easiest way to disconnect/disable the center channel is to remove one of the wire pins for the center channel from the connector at the audio amplifier, which is located on the left sidewall of the trunk. The two wires (one is yellow and the other is light blue) for the center channel connect to the amplifier via connector/plug "X2". The yellow wire goes to pin# 12 of X2; the light blue wire goes to pin# 13 of X2. Note there are a total of 4 connectors that plug into the audio amplifier - X1, X2, X3, X4.
    As further info & reference, below are links to the wiring diagram for the Nav/Infotainment/5.1 Surround system on the 2008+ 2nd gen CTS :
    Wiring diagram page 1 of 4: http://www.mediafire.com/view/t9qx0w...ier-1-of-4.pdf
    Wiring diagram page 2 of 4: http://www.mediafire.com/view/ppnoip...ier-2-of-4.pdf
    Wiring diagram page 3 of 4: http://www.mediafire.com/view/uufu5u...ier-3-of-4.pdf
    Wiring diagram page 4 of 4: http://www.mediafire.com/view/69fvao...ier-4-of-4.pdf
    Cheers
    RAB
    hauler, Acdcpsp and dhendo like this.
    Mar 2014
    31
    5
    Quote Originally Posted by RAB View Post
    With the first 2nd gen CTS I owned (a fully optioned 2008) I discovered that sound wasn't coming out of the center channel speaker most of the time. I discovered the issue while playing a 5.1 DVD-A disc. The problem was traced to poor signal continuity between a couple of the connector/plug pins and audio amplifier mating pins. The problem was resolved at the dealer by replacing/installing new pins on all connectors to the amplifier.
    Cheers
    RAB
    This is exactly what I want to do. Is it possible to remove the connectors and still be able to put them back in the future if need be? I do not want to cut the wires.
    Mar 2014
    31
    5
    I ended up popping out of of the connectors using a small screw driver. Thanks everyone for the comments.
    hauler likes this.
    RAB's Avatar
    RAB
    Jun 2007
    Ontario, Canada
    2,108
    Glad to hear it worked out for you.
  13. Remove Advertisements
