Wheels
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Slee_Stack
2008-2013 Cadillac CTS General Discussion Discussion, Wheels in Cadillac CTS Second Generation Forum - 2008-2013; Hi all. Brand new to the forum and first time Cadillac owner. First off great forum. Very informative. I have ...
    earthpig13 is offline Cadillac Owners Member
    Automobile(s): 2008 CTS 4 DI
    Apr 2014
    15
    Wheels
    Hi all. Brand new to the forum and first time Cadillac owner. First off great forum. Very informative. I have a 08 CTS4 DI with shiny chrome type wheels. What are they made from. I'd like to get rid of the curb rash on them by sanding and polishing. Are they aluminum ?Has anyone ever tried this ? Is there a clear coat on them ?Any help is appreciated.
    928S is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS 3.6L DI RWD, GMPP new engine 11/2013
    Oct 2005
    USA
    2,092
    Re: Wheels
    Yes, factory OEMs were highly-polished (not chromed) clearcoated aluminum alloy. To confirm, look for RPO code "P63" on the placard attached to underside of spare tire cover in trunk floor.
    Welcome to the forum !!!
    loosend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DI RWD w/ Prem & Perf Pkgs Blk/Blk FE2
    Nov 2009
    Maryland
    132
    Re: Wheels
    There is a color in the coating on the "polished" P63 rims to make them look polished so you will see a difference between the coating and the actual aluminum when you sand the gouges out and go through the coating. I used the coarsest grit sandpaper that would remove the gouges and then went to a finer grit until it was smooth and used a heavy grit Meguires cleaner for the final step. Don't sand a larger area than necessary and I have no idea why GM painted the rim and called it "polished" but they did. You repair will be noticable but it wont stick out as much as the curb rash so take your time.
    Slee_Stack is offline Cadillac Owners Fanatic
    Automobile(s): 2014 CTS Wagon RWD Premium, Used to own 2005 STS 1SG
    Jan 2010
    GA
    324
    Re: Wheels
    All aluminum, regardless if polished, oxides without a protective coating, annodization, chemfilm treatment or other top layer.
    That is why GM 'painted' them with a clear coat.
    When you are done with your rim repair, you will want to apply whatever clear coat GM used or something similar.
    loosend likes this.
    Apr 2014
    15
    Re: Wheels
    Thanks for all the help. Not sure what I'm going to do yet.
    Nov 2009
    Maryland
    132
    Re: Wheels
    Quote Originally Posted by Slee_Stack View Post
    There is a bright metallic color in the coating but it does make the finish on the rim very brilliant with minimal care--Until you gouge it. Thanks for the information on this and maybe I will use the wife's clear nail polish on my repair for protection. She will love that. LOL
  9. Remove Advertisements
