08 CTS wheel bearing
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By mevaristo
2008-2013 Cadillac CTS General Discussion Discussion, 08 CTS wheel bearing in Cadillac CTS Second Generation Forum - 2008-2013; Hey. I've looked around and can't do find the answer. So my apologies if there is one out here already. ...
    mevaristo's Avatar
    mevaristo is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS
    Jun 2012
    40
    161
    I just received my two assemblies but I don't see any abs sensors on them. Are the sensor external ? For some reason I was expecting to see them on the bearing ..
    remmyman's Avatar
    remmyman is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-4, Sedan,Tuscan Bronze
    Feb 2014
    upstate ny
    306
    Re: 08 CTS wheel bearing
    They are a separate item that plug into the hub.
    mevaristo's Avatar
    Jun 2012
    40
    161
    OK thank you. So theoretically I should be able to re use the ones I got correct ?
    rrodz88 is offline Cadillac Owners Member
    Jul 2014
    3
    Did you ever get an answer about the ABS sensors? I just received a replacement bearing assembly but no ABS wire. Can the old one be used?
    mevaristo's Avatar
    Jun 2012
    40
    161
    Ya the sensors are not embedded in the bearing. Which is actually really nice. However if you aren't careful removing the old bearing you will break them lol. Its worth taking the extra 5 minutes and remove the abs sensor before removing the bearing. I ended up breaking one
    rrodz88 likes this.
  8. Remove Advertisements
