Results 1 to 7 of 7
Thread: blown fuse stopping codes from being scanned?
    Jan 2014
    31
    64
    2008 cts4 di. Is there a fuse that allows a scanner to pull codes? Just stopped st my local autozone to have my CEL scanned and 2 scanners later neither would scan the ecm, theyd power up but never connect. The autoZone Guy told me there was a fuse that must be blown preventing the scanner from connecting. Is this possible? Never heard of a fuse stopping a scanner from pulling a code, if this is in fact true.. which fuse would I need to change? One thing aftet another currently with this car
    calif phil is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS
    Jan 2013
    Kansas
    513
    It's usually the cigarette lighter fuse that powers the ALDL. A lot of the time the fuses will blow due to poor fitting cell phone chargers.
    Jan 2014
    31
    64
    Re: blown fuse stopping codes from being scanned?
    Quote Originally Posted by calif phil View Post
    I have one from a gas station, wouldn't be suprised if that's whats causing it. will check my manual for which fuses to check. Thanks for the reply!
    Quote Originally Posted by 08BlueCTSDI View Post
    Is it the one that says Aux power on the manual? Don't see any that clearly state Cig lighter
  5. #4
    Cougar281 is offline Cadillac Owners Fanatic
    Automobile(s): 04 Silverado Duramax, 95 Cougar, 2010 CTS4 Premium
    Jan 2012
    St Charles, MO
    36
    173
    If the scanner powers up, then its almost certainly not a fuse.
  6. #5
    jovi440 is offline Cadillac Owners Fanatic
    Automobile(s): 08 CTS
    Dec 2008
    Baton Rouge La
    176
    All OBD2 diagnostic testers I've seen or used connects to the DLC under the dash and powers up from there. Never seen one that powers up from a "cigarette lighter plug"not saying there are not any, I have just never seen one. A lot depends on the person who is using the tester and the amount of knowledge he has on how to use it. I have a Innova 3100 and when I first got it I had a little problem getting it to link up to some vehicles until I learned more about it and how it worked. To be honest, I read the manual.
  7. #6
    Jan 2012
    St Charles, MO
    36
    173
    Quote Originally Posted by jovi440 View Post
    The OBD2 port is typically powered by the same circuit as the cigarette lighter/power port...
  8. #7
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,549
    Perhaps you have a cig lighter that is switched, i.e., ignition on-lighter on, ignition off-lighter off.
  • You may not post replies
