High mileage service recommendations AWD 3.6 2008
Results 1 to 6 of 6
2008-2013 Cadillac CTS General Discussion Discussion, High mileage service recommendations AWD 3.6 2008 in Cadillac CTS Second Generation Forum - 2008-2013; Any suggestions on what to service. All I've done is change the oil, always check oil level between service and ...
    JBsZ06 is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 CTS AWD FE2 DI 304hp
    May 2004
    739
    Any suggestions on what to service. All I've done is change the oil, always check oil level between service and change the tires...
    I'm closing in on this light duty service CTS with 50k miles....
    Do I change the transmission and differential fluids ?
    Check the driveshaft to transmission couplings ? Etc?
    My me...I mean my service tech.
    Car runs great....one time as I was starting off at a light the car didn't move which was kind of weird...it moved much slower than I thought it should and it was but a brief moment in time....wife didn't even notice....but I did...other than that one time...the car drives perfect.
    Thanks in advance.
    Scott2012's Avatar
    Scott2012 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 AWD CTS
    Jul 2012
    Minnesota
    40
    261
    Re: High mileage service recommendations AWD 3.6 2008
    If you bought it new, follow the owners manual.
    However, when I buy used... I change all the fluids, air filter, everything so I can ensure everything is done right and on time. I believe in synthetic fluids.
    928S is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS 3.6L DI RWD, GMPP new engine 11/2013
    Oct 2005
    USA
    2,092
    JBsZ06,
    Are you asking for ad hoc opinions, in lieu of GM/Cadillac's recommended maintenance schedule listed in the 2008 CTS Owner's Manual?
    Good luck, you'll need it.
    Bandit1's Avatar
    Bandit1 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 ATS 3.6 RWD Premium
    Oct 2008
    Ashburn, VA
    497
    This is what I do at 60K miles:
    - Replace Spark Plugs & Check wires
    - Replace hoses & belts & check belt tensioner pulley
    - Change air filter
    - Change cabin air filter
    - Flush radiator
    - Change brake fluid
    - Change power steering fluid
    - Change oil & filter (consider engine flush before dumping oil)
    - Change AT fluid & filter (complete change, not just pan)
    - Change diff(s) gear lube
    - Clean MAF & throttle body
    Hemi_Tom is offline Cadillac Owners Member
    Automobile(s): 2008 CTS 4 DI. '98 Catera
    May 2007
    Springboro, Ohio
    58
    High mileage? That isn't high mileage. My 2008 AWD 3.6 Di has over 151,000 miles on it! (Is this the record?) It's had the timing chain done at 100,000 and I just had the output shaft of the transmission and input shaft of the transfer case replaced. (stripped the splines) Other then fluid changes, plugs, etc. it has been great!
    May 2004
    739
    Thanks guys,
    Sounds like a fluid change for the differential and transmission at around 50k miles.
    Change the air filter and I should be good to go.
    The car definitely doesn't get hard usage....in fact it's very very light usage and that was really my question. The owners manual says under hard use.....(which the car doesn't get) my wife drives very gently. She loves the car.
    I enjoy driving weekly on date nite and the cars Been trouble free ...
  9. Remove Advertisements
