3.6DI Injector noise pattern
Results 1 to 4 of 4
2008-2013 Cadillac CTS General Discussion Discussion, 3.6DI Injector noise pattern in Cadillac CTS Second Generation Forum - 2008-2013; What is a normal noise pattern for a 3.6DI? My experience with GDI motors is limited to this one engine, ...
    Cougar281 is offline Cadillac Owners Fanatic
    Automobile(s): 04 Silverado Duramax, 95 Cougar, 2010 CTS4 Premium
    Jan 2012
    St Charles, MO
    36
    173
    What is a normal noise pattern for a 3.6DI? My experience with GDI motors is limited to this one engine, and I know they sound different than SFI motor. The reason I ask is mine has a pattern that may or may not be normal. It has a louder tick at regular intervals that sounds like it's once every cycle, as if there's something different about one injector, and every time it fires, it sounds different than the other 5 injectors. Does this sound normal, or does it sound like there may be something up?
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Re: 3.6DI Injector noise pattern
    It's the fuel pump ticking which increases as revs increase. You get used to it. Turn the radio up a bit.
    Jan 2012
    St Charles, MO
    36
    173
    It doesn't bother me and from inside, I can't hear it at all. Just from outside. Was just curious about the one tick that's louder than the others.
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    The injectors will also hammer pretty loud as they are working with app. 2000 PSI. We see very few failures, and it is normal.
  7. Remove Advertisements
