Tire pressure monitor WAY off when cold
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Like Tree5Likes
2008-2013 Cadillac CTS General Discussion Discussion, Tire pressure monitor WAY off when cold in Cadillac CTS Second Generation Forum - 2008-2013; I have this issue with my 2010 CTS Wagon every time it gets cold (like the past week in Colorado ...
    seasar is offline Cadillac Owners Member
    Automobile(s): CTS wagon
    Apr 2012
    I have this issue with my 2010 CTS Wagon every time it gets cold (like the past week in Colorado with temps near 0 f). The pressure in my tires is 35+ and the system reads 30-31 per tire...consequently the low tire pressure alarm is always on.
    I trust my handheld gauge and the system matches when it isn't frigid.
    I know of the hidden Navi screen but I can't figure out how to use the tire pressure tuning screen and can't find instructions on the internet.
    At this point I'd be happy just being able to turn the thing off in the winter months...it adds no value if it is also telling me I have four flats.
    I don't want to overinflate my tires in the winter, and harm the ride and traction, just to shut the thing up.
    I am still on the original tires and wheels but the car is out of warranty.
    Anyone else have and fix this problem?
    Thanks.
    Sent from AutoGuide.com Free App
    Pdabs's Avatar
    Pdabs is offline Cadillac Owners Enthusiast
    Automobile(s): CTS4
    Dec 2011
    NJ
    34
    600
    Did you check your tire pressure with handheld when it's frigid?
    You do realize that as temperature drops so does the pressure in your tires. So if you're at recommended during an average 65 degree day.... You're tires will have less pressure on a frigid day, but as you drove the tires will go back to normal pressure as heat builds up.
    Panzer Leader's Avatar
    Panzer Leader is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS 3.6 V6 RWD Performance Sedan
    Jun 2012
    Mandeville, Louisiana
    588
    Re: Tire pressure monitor WAY off when cold
    The tire pressure monitoring system is off. Same on my G8... Never reads the same as the handheld gauge.
    C&C's Avatar
    C&C
    C&C is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,949
    Generally accept 1 psi per 10 degrees F (up or down, accordingly); it sounds as your TPMS is functioning properly.
    928S likes this.
    toolman8 is offline Cadillac Owners Member
    Automobile(s): 1929 Cadillac 341B sedan, CTS4 3.6 Performance Wagon
    May 2011
    Cleveland, OH
    24
    I am having the exact same problem. After my fiasco with flat tires, broken sensors, and warning lights on Thanksgiving, I was driving today and it told me I had ANOTHER flat. Pulled over immediately hoping to not have to buy another $300 tire and found all four tires still round and holding air. Scrolled through the menu and saw that right front was 30, rears were both 33, and left front was 26. OK, fair enough, get air at next exit. Fill it up using my hand-held gauge, left front now reads 32 on the hand-held gauge and just to be safe, I checked the rest by hand, too. Right front reads 31 on the hand-held, rears are about 32-33, but dashboard now says right front is 36, left front is 29, and the warning light is still on. I only filled the left front, but somehow the right front got 6 more PSI? It's been consistently cold here, and I double-checked them all at Thanksgiving, so all my current pressures are at current temperatures (mid-20s), not leftover from warmer weather so I can't attribute it to the cold. The system just doesn't work very well in the cold.
    PLEASE, can I get rid of this crap? I know it's mandated by the Feds and all, but is there a way to get rid of it without dealing with the warning lights on the dash? Or am I stuck with the old electrical tape solution? My dissatisfaction with this car and its technology only grows.
    Espi is offline Cadillac Owners Member
    Automobile(s): 2011 CTS Premium
    Sep 2013
    Tampa Bay
    46
    60
    I live in FLA and just went through this. The responses I got in my thread on this forum was to fill each tire to 37 PSI (I have 19" Summer performance tires and the recommended PSI per tire is 35). I bought a digital gauge from Target and inflated each tire to 37 PSI (warning light had indicated each tire was underinflated).
    The light shut off after that.
    If the light still comes on, I would visit the dealer as a last resort.
    calif phil is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS
    Jan 2013
    Kansas
    513
    If you have your tires rotated most shops do not reset the TPMS to read the correct wheel position so the RF sensor could now be on the LF and so on.
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    The monthly report I get from ON* shows air pressure much different from the DIC and the DIC never matches my hand held gauge. I wonder if a nitrogen fill would help.
    Cougar281 is offline Cadillac Owners Fanatic
    Automobile(s): 04 Silverado Duramax, 95 Cougar, 2010 CTS4 Premium
    Jan 2012
    St Charles, MO
    36
    173
    Quote Originally Posted by C "T" ess View Post
    I doubt it would hurt, but I wouldn't pay extra for it. If you can get it for free, go for it. Otherwise, just keep an eye on your pressures and fill as needed.
    FWIW, my DIC shows all tires within 1psi of what my mechanical gauge says, and the TPMS in my truck has always been accurate as well. It's about 20*F here now.
    As far as disabling the system without any warnings, what I've heard of some people doing is having the sensors removed, putting them in an airtight 'pressure vessel' and pumping it up to the expected pressure and sticking it under a seat or somewhere otherwise out of the way.
    HR-cts is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS4 wagon 3.6
    Nov 2013
    Ontario
    129
    "...Anyone else have and fix this problem?..."
    Yes, pump up your tires - WHEN COLD - to whatever it says on the door or door jamb sticker, and ignore the TPM.
    ALWAYS walk around the vehicle before you get in and visually check the tires to make sure they look inflated - do this ALL THE TIME, Winter, Summer, Fall, Spring...!
    Get a piece of black electric tape and place over the warning light.
    Apr 2012
    I inflated to the recommended pressures when it was 10F and the tires were cold (car had been sitting). TPMS still reads low...on the Cadillac it isn't just a warning light as it also has a digital readout on the dash that I typically have set to indicate speed.
    So besides the always on dash light I have to acknowledge the alarm 6 times every time I start the car. That's ridiculous. Why would I ever trust this system in the winter to identify a flat tire!
    Nov 2013
    Ontario
    129
    well. in that case i would pop over to the garage and have them re-set the system so that it doesn't come on if the tires are inflated to proper pressure.
    can't be all that expensive or time consuming.
    t5mika is offline Cadillac Owners Member
    Automobile(s): CTS
    Dec 2011
    50
    I was stumped with the same thing because I was being dumb. In cold mornings my left rear was showing 29psi. I set it to spec, drove around and still 29. Afternoon the warning went away with warmer weather. It took me a couple of weeks to realize the the tires were rotated and the sensors were not reset. It was the left front that was really at 29psi. I set all tires to 35 at 70 degrees (as I should've done from the start), and no warnings since then. The pressure (and the reading) drops to 31psi when the weather is in the low 30s.
  16. #14
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,253
    I rotate my tires myself. I don't bother with the TPMS. When I check one tire I check them all. The readout on my dash is only an indicator...you can't beat checking your tires with a good quality gauge yourself. Money and time well spent.
  17. #15
    Wolfster's Avatar
    Wolfster is offline Cadillac Owners Fanatic
    Automobile(s): 08 CTS4 3.6DI
    Dec 2013
    Mississauga, Ontario Canada
    70
    313
    Quote Originally Posted by tinman View Post
    I agree...it is money and time well spent. I use the TPMS for a guide sometimes, but usually check pressure myself and I have a compressor in my garage also.
  18. Remove Advertisements
