The 3.0 and 3.6 Intake valve cleaning guide
Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Like Tree5Likes
2008-2013 Cadillac CTS General Discussion Discussion, The 3.0 and 3.6 Intake valve cleaning guide in Cadillac CTS Second Generation Forum - 2008-2013; Thought I would cover cleaning the intake valve deposits manually. Tools needed are 10mm & 13mm socket & ratchet wrench ...
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    Tools needed are 10mm & 13mm socket & ratchet wrench to remove the IM, a 19mm (3/4") socket to turn the crank as you move from port to port to ensure both valves are in the closed position, various long picks or narrow flat blade screw driver, and a set of 1/4" hex end brushes that can be fitted to an extension and drill to clean the deposits, shop vac and compressed air nozzle to remove the deposits as you loosen and clean them from the valves. This can be done in 2-6 hours depending on the tools and how handy the DIY guy/gal is:
    Brushes below show how they clog with debris, clean with brake clean between each port so they will still be effective.
    This can be done by removing the intake manifold, plug each intake port with a clean rag or better yet blue masking tape to prevent any debris from falling into a cylinder that may have a valve open, start with cylinder/port # 1 and make sure the intake valves are both closed by looking into the port with a flashlight or boroscope.
    The deposits will be anywhere from a thick "goo", to baked on rock hard...and so all know, upper induction cleaning is helpful, but you do not want to do it very often as the deposits when loosened while the engine is running, the smaller ones, will be forced between the piston and cylinder-wall and cause scouring. So ONLY do a solvent cleaning once in a great while, and with a good catchcan like the RX, you should have very little build up in the future. Below is a picture showing a low mileage piston with several upper induction cleanings done....if a little is good, a lot must be real good? No. There is a trade off for doing the easy quick fixes. Same as to much fuel treatment/injector cleaner will shorten injector life:
    So after making sure the valves are both closed so no deposits can fall into the cylinder, start with the long pick or screwdriver work the biggest accumulation loose first (don't worry about scratching, the valves and seats are hardened steel and there will be damage done). Use the shop vac to keep sucking the debris as it is loosened. After you get as much pried loose this way, then start with the brushes. You will be able to get most all the deposits cleaned and end up with this when completed:
    Vs this to start:
    After you have completed one port, then spray compressed air into the port to remove any particles the vac did not and clean and tape up that port and move to the next.
    I know this is not long and detailed, but should give most the steps to do this. The difference will be very noticeable in both power and fuel economy. Remember, it took time for this to gradually build up so most never notice the degradation but sure do the improvement after completing this.
    Hemi_Tom is offline Cadillac Owners Member
    Automobile(s): 2008 CTS 4 DI. '98 Catera
    May 2007
    Springboro, Ohio
    58
    Re: The 3.0 and 3.6 Intake valve cleaning guide
    Good write up. Thanks!
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,708
    Nicely done.
    Me, well, I would rather drive the 4 hours and have you do it. Yes, I could do it but it would take me forever.
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    LOL! We charge $400 to do these....compared to $150-$250 for an upper induction cleaning that only cleans part of the buildup.
    Acdcpsp is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 3.6 LY7
    Feb 2013
    236
    I have the non di 3.6. Do I have the same issue with build up on my valves?
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    No. Non DI the intake valves are constantly showered in the detergent fuel so deposits never get a chance to form (unless you run cheapo non-brand gas, then over a long time some deposits will form, but nothing like the DI engines). On a DI engine only air flows past the valves, the fuel is injected directly into the combustion chamber at 2000 plus PSI (depending on the engine) so it is a huge issue on them. You can still benefit greatly with a oil separating catchcan like the RX one though to keep the piston ringlands clean and better fuel economy.
    blankster is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS Premium AWD 3.6 DI (Sold)
    Sep 2009
    Chicago Area
    472
    Does running something Sea Foam through a vacuum line help?
    Mistercoffee2's Avatar
    Mistercoffee2 is offline Cadillac Owners Enthusiast
    Mar 2012
    Houston TX
    516
    Has anyone considered DIY using a sand blaster nozzle and crusher walnut shell? Walnut shell is cheep, <$1.50 a pound.
    Stoked's Avatar
    Stoked is offline Cadillac Owners Member
    Automobile(s): 2010 CTS 3.6
    Nov 2013
    30 miles north of DFW, Texas
    40
    15
    Quote Originally Posted by Mistercoffee2 View Post
    I know that's big with the BMW guys, but I think they have special tools for that. I read on another forum where a guy tried that on his Camaro with mixed results. Wetness on the valve caused the shells to stick in there and were difficult to get out. I'd be afraid of leaving debris in there, or it finding its way in somewhere else.
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    Stoked is correct. The BMW's seem to bake it on harder than the GM engines and the one we did in this thread was pretty gummy. The system the shops use with BMW has a lexan plate that covers the port and a shop vac attaches right to a fitting on it and the blast nozzle can be directed all around.
    As for Seafoam, BG, or any of the other solvent upper induction cleanings, yes, they do work to an extent but don't clean it all, and if used to often you will incure damage to the piston/cylinder walls from the hard particles as they loosen as the smaller ones are pushed between the piston and cylinder wall causing scouring. Using it now and then is fine though and after installing a good catchcan like the RX can we recommend doing one if not the manually cleaning shown here.
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    Bumping this back up to keep it available for those wanting to learn.
    wcthunder likes this.
    dmeray1 is offline Cadillac Owners Member
    Automobile(s): CTS
    Jun 2013
    Alllen Park, MI
    66
    Source for brushes?
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    Harbor freight....these are stainless we got from local supplier, but amazon has them as well.
  16. #14
    tinman's Avatar
    Jul 2006
    9,708
    If you need other sources PM me. They will be more expensive, however.
  17. #15
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    Bump for those wanting to do the manual cleaning.....this is by far the best result in dealing with existing deposits.
  18. Remove Advertisements
