No Low Beams or DRL's
Results 1 to 2 of 2
2008-2013 Cadillac CTS General Discussion Discussion, No Low Beams or DRL's in Cadillac CTS Second Generation Forum - 2008-2013; I'm in a bit of a tight spot, because the other day my low beams and DRL's stopped working on ...
    Hbuck72 is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac CTS
    Dec 2010
    8
    I'm in a bit of a tight spot, because the other day my low beams and DRL's stopped working on my 2008 CTS. I've checked all of the fuses and they are fine, I've moved and switched around the underhood relays for the lights around with other relays, and even changed out the large DRL (Non-HID) relay, because I couldn't find a similar relay to swap it with. I've also changed the light/turn signal lever in the car.
    My high beams work, and when I manually try to turn the low beams on the side marker lights and tail lights come on, but no low beams.
    Anyone have any ideas? I'm trying to save myself from spending a fortune at the dealership.
    Tbbt is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,264
    Re: No Low Beams or DRL's
    There was a recall for lights on the early 2nd Gen models where the connector was melting causing problems. Search for this problem and MAYBE that is where your problem originates!
    Good Luck, Marv
