2008 Cadillac CTS RWD Engine Replacement Vin 7
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Like Tree2Likes
2008-2013 Cadillac CTS General Discussion Discussion, 2008 Cadillac CTS RWD Engine Replacement Vin 7 in Cadillac CTS Second Generation Forum - 2008-2013; I need to replace the engine in my 2008 Cadillac CTS RWD. The engine code on the VIN is 7. ...
    squeekyeagle is offline Cadillac Owners Member
    Automobile(s): 2008 CTS
    Nov 2013
    36
    5
    I need to replace the engine in my 2008 Cadillac CTS RWD. The engine code on the VIN is 7. Im looking up engines and I see a lot of CTS/STS engines for sale with engine code V. It looks like the "V" is for an AWD vehicle. My question is this...Will the engine code V work for the 7? It is the 3.6
    Cougar281 is offline Cadillac Owners Fanatic
    Automobile(s): 04 Silverado Duramax, 95 Cougar, 2010 CTS4 Premium
    Jan 2012
    St Charles, MO
    36
    173
    Re: 2008 Cadillac CTS RWD Engine Replacement Vin 7
    Vin '7' is for the LY7 3.6L SFI engine, wheras VIN 'V' is the LLT 3.6L DI engine, so no, a LLT will not work in a vehicle that had a LY7.... without MAJOR work (Harness and ECM replacement at minimum), if it would work at all.
    Nov 2013
    36
    5
    I was afraid of that. Thanks
    07cts-vee is offline Cadillac Owners Member
    Automobile(s): 07 cts-v
    Oct 2013
    40
    12
    What happened to your engine? 08 is pretty new to need a engine.
    Nov 2013
    36
    5
    Quote Originally Posted by 07cts-vee
    Bottom line-it ran out of oil. The mystery is how it happened. It never smoked, garage floor is spotless and it was serviced at the dealership. Check engine light never lit up and all gauges showed normal. By the time I got suspicious and checked the oil, it was over 4 qts low and the damage was done. I suspect the dealership not putting in the synthetic I paid for but I have no way to prove it...38k miles on the engine with a thrown rod.
    MKWAGON is offline Cadillac Owners Fanatic
    Automobile(s): 2010 AWD Sportwagon, Diamond white, 3.6 DI
    Jun 2010
    Toronto, Ontario Canada
    57
    193
    What made you suspicious?
    Nov 2013
    36
    5
    Quote Originally Posted by MKWAGON
    There was a slight rattle on acceleration and the oil pressure dropped to around 40
    Oct 2013
    40
    12
    That sucks big time. I can understand your frustration I would be pissed. Doesn't it have a low oil level warning system and if it does it doesn't sound like it worked. Might be one route to look at on getting some assistance with repairs don't know what kind of warranty you had.
    Jan 2012
    St Charles, MO
    36
    173
    Quote Originally Posted by 07cts-vee View Post
    From what I've gathered, no, it doesn't really have a low oil warning. Supposedly it can tell if its low on oil from the oil pressure somehow, but at that point, you've already started to starve the engine of oil and the damage is done. My truck has a float in the pan that will tell you before you starve the engine.
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,269
    I am truly sorry to hear this.
    I am not being nasty when I say you have to check your oil levels regularly. What was the time frame from when you last checked your oil to when you discovered your problem?
    Nov 2013
    36
    5
    Quote Originally Posted by tinman
    I am truly sorry to hear this. I am not being nasty when I say you have to check your oil levels regularly. What was the time frame from when you last checked your oil to when you discovered your problem?
    Hindsight, especially in this scenario, is 20-20. The oil was changed at approx. 36k. I didn't and still don't consider it taking a risk to not check the oil on a 38k mile vehicle that leaves no spots in the garage, never smokes, shows no warning lights, shows all normal gauge readings, and gets regular 3k services from the dealer. I do check the oils once a month in my truck which is 21 yrs old with 115k miles and my convertible which is 13 yrs old and 88k miles. It's partially my fault for trusting the dealership because we all know their quick service techs are not exactly their A squad...
    tinman's Avatar
    Jul 2006
    9,269
    I can't disagree with your logic. Truly sucks in a major way.
    ctsclub is offline Cadillac Owners Member
    Automobile(s): Black Raven 2008 CTS SFI
    Apr 2012
    Kansas City, Kansas
    26
    22
    Quote Originally Posted by squeekyeagle View Post
    Not to HiJack this thread but my oil pressure in my 08 gets down to 25ish after warm up and at idle is that too low? Iv seen another thread where that is within the normal bounds for it. This is the SFI engine not the DI. Just got me worried about it now!
  16. #14
    Acdcpsp is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 3.6 LY7
    Feb 2013
    236
    Quote Originally Posted by ctsclub View Post
    Mine does that too and I check my oil once a week and it's always full.
  17. #15
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Just curious, if the deal had used dino oil, where would four quarts go so quickly? You say no smoking or leaking. I know the full syn or Dexos provide for better lubrication but I think there is something deeper here, like maybe the dealer never put anyoil in at all.
    Big_Jim likes this.
  18. Remove Advertisements
