"Clunk" in Right Rear
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Joe
2008-2013 Cadillac CTS General Discussion Discussion, "Clunk" in Right Rear in Cadillac CTS Second Generation Forum - 2008-2013; I have developed a "Clunk" in the right rear when going over bumps in the road.. Removed everything out of ...
    Crankpin is offline Cadillac Owners Member
    Automobile(s): 2008 CTS
    Aug 2013
    60
    I have developed a "Clunk" in the right rear when going over bumps in the road.. Removed everything out of trunk and drove and it's still there. Sounds heavy and like something is loose. Any history out there. Thanks.
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Re: "Clunk" in Right Rear
    If you search recent posts, you will find that this condition has been covered several times. Your symptoms are the same and the repair required will most likely be the same. So, to answer your question;yes, there is a history here.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,687
    Quote Originally Posted by Crankpin View Post
    Hello Crankpin,
    I apologize you are hearing a vehicle noise with your right rear. I would like the opportunity to further discuss this with you. Please contact me via private message and include your contact information, VIN and current mileage. I look forward to hearing from you.
    Sincerely,
    Laura M.
    Cadillac Customer Care
    Joe
    Joe is offline Cadillac Owners Fanatic
    Automobile(s): 08 CTS blk/blk
    Jul 2010
    MA
    68
    383
    I'll save you a lot of time. I already did what you did and between this site and my mechanic we found the culprit. I could have sworn it was a bad shock; I pulled the back seat out and checked the bolts but that wasnt it. The bottom of the shock is attached to a part called the knuckle. The grommet is worn out allowing the shock to rattle. You can but the grommet with some research but I have opted to buy the knuckle and let my mechanic install it. I can pull and push on the shock but it does not move, that fooled me. Friday I had it on the lift again for an oil change and this time we twisted it and there it was loose as hell by comparison to the other side. Best of luck
    OMG likes this.
    sdobert's Avatar
    sdobert is offline Cadillac Owners Member
    Automobile(s): 2009 CTS-4
    Jan 2013
    48
    That is exactly it...rear knuckle, I had the passenger side done three months ago and my drivers side is getting repaired as I write this.
    Mar 2010
    Detroit, USA
    12,687
    Quote Originally Posted by sdobert View Post
    Hello sdobert,
    I apologize for any inconvenience you've experienced while resolving your vehicle concerns. Please let us know how your current drivers side repair goes. If you have any questions you would like to further discuss, please contact us via private message so we can assist.
    Sincerely,
    Laura M.
    Mistercoffee2's Avatar
    Mistercoffee2 is offline Cadillac Owners Enthusiast
    Mar 2012
    Houston TX
    516
    Both sides replaced on my 2008 before 50K miles for the same noise. Right side April 2012, left side July 2013.
    Cadillac Cust Srv: Please, no apology for something that GM has known about for years and who't fix.
    Advice to anyone thing of buying a used 2008 - 2012 CTS: Have the dealer replace both rear knuckle first.
    dmeray1 is offline Cadillac Owners Member
    Automobile(s): CTS
    Jun 2013
    Alllen Park, MI
    66
    Any idea how hard it is to replace said knuckles? Any idea on costs for parts.
    Mar 2012
    Houston TX
    516
    Quote Originally Posted by dmeray1 View Post
    Cost $140-$150 shipped on eBay. I replaced the left one myself. Not a bad job with the correct tools. Should be do-able in 2 hrs.
    I got mine here for a couple dollars less the eBay.
    http://www.group1autoparts.com/parts...ion-components
    sdobert's Avatar
    Jan 2013
    48
    Update: drivers side rear knuckle replaced and the hub assembly. Everything sounds much better so far.
    Mar 2010
    Detroit, USA
    12,687
    Thank you for updating the thread, sdobert. I am glad your vehicle concern is resolved now and everything sounds much better. If any questions arise, don't hesitate to contact us via private message so we can assist.
    Sincerely,
    Laura M.
  14. Remove Advertisements
