2009 CTS Manual Transmission and LSD Oil Change
Results 1 to 5 of 5
Like Tree3Likes
  • 2 Post By jurzdevil
  • 1 Post By tinman
2008-2013 Cadillac CTS General Discussion Discussion, 2009 CTS Manual Transmission and LSD Oil Change in Cadillac CTS Second Generation Forum - 2008-2013; I just changed the oil in my manual transmission and limited slip differential. Fairly painless process, toughest part is getting ...
    jurzdevil is offline Cadillac Owners Member
    Automobile(s): 2009 CTS 3.6DI FE3 MN6
    Dec 2008
    32
    58
    I just changed the oil in my manual transmission and limited slip differential. Fairly painless process, toughest part is getting the car level on 4 jackstands.
    I got started here http://www.cadillacforums.com/forums...w-lsd-pic.html but noticed some differences. I have an 09 3.6 DI with MN6, FE3 suspension and the LSD. The pic below is the fill/drain plugs on my differential. I used the same Royal Purple 75W-90 gear oil with the friction additive. 10mm hex key for each plug.
    I found some info on the 6 speed manual over at the Camaro forums. Same Aisin AY6 was used there. Transmission takes 1.9 quarts of 75W-90. I used Pennzoil Synchromesh as it met the GM recommendation for transmissions with synchronizers. The space around the transmission is a bit tighter than on the Camaro but its still easy. Both pictures are from the drivers side. Plugs are both 15/16".
    Merge and OMG like this.
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,339
    Re: 2009 CTS Manual Transmission and LSD Oil Change
    Sigh, I wish I could use this info, but I drive a slushbox.
    EVH5150 likes this.
    JCBCTS is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS Base Manual Tran
    Apr 2011
    46
    314
    I have the other V6 Manual - Ok that is exaggeration but they're aren't many of them out there! Below is the link to the Camaro thread detailing the fluid change. Thanks for posting the pics. I have 50k on my 2008 and I'm going to change mine soon and might as well do the differential while i'm at it.
    http://www.camaro5.com/forums/showthread.php?t=100836
    Apr 2011
    46
    314
    I changed my Manual Transmission and Rear Differential (RWD) fluid this weekend. Used 2 quarts of Valvoline Synchromesh in the tran and 2 qts of Lucas 75W90 synthetic in the differential. Easy job - thanks for the pictures. Also I found this very detailed information on the AY6 transmission. Some light reading for those of you with the Manual Transmission!
    http://www.anxa.de/camaro2010/werkst...rans%20ay6.pdf
    OMG's Avatar
    OMG
    OMG is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 3.6DI
    Mar 2013
    Northern IL Suburbs
    30
    231
    Gawd I wish I had a manual (jealous here) you have the combo I originally wanted (manual with FE3). Miss rowing the gear so BAD!
    Anyways enough crying from me. Awesome write up and thanks for the link to my thread!
  8. Remove Advertisements
