TPMS Question
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Like Tree1Likes
2008-2013 Cadillac CTS General Discussion Discussion, TPMS Question in Cadillac CTS Second Generation Forum - 2008-2013; Just a quick question. Because Canada winters are so fantastic i will be switching to winter tires fairly soon. Now ...
    Srsbisns's Avatar
    Srsbisns is offline Cadillac Owners Member
    Automobile(s): 2009 CTS 3.6 DI AWD
    Oct 2013
    14
    TPMS Question
    Just a quick question. Because Canada winters are so fantastic i will be switching to winter tires fairly soon. Now the tire place i go to is trying to tell me they can adjust the snow tires so it works with my tpms for 200 bucks From reading this: http://www.cadillacfaq.com/faq/answers/tpm/index.html my understanding is at first the tpms system will say that i have 0 tire pressure and display a warning but once i get home and stick the stock tires with the tpms sensors in them in my basement and start driving the car normal the system will deactivate all together until i swap back to my regular stock rims. Am i understanding this correctly? or am i just going to have to deal with the tpms warning all winter?
    Mistercoffee2's Avatar
    Mistercoffee2 is offline Cadillac Owners Enthusiast
    Mar 2012
    Houston TX
    516
    Re: TPMS Question
    Quote Originally Posted by Srsbisns View Post
    The TPMS sensor is mounted to the inside of the wheel by the valve stem. Changing tires should not effect TPMS function. Unless your tire place removes or damages them. Fine another tire place.
    99flhr is offline Cadillac Owners Enthusiast
    Automobile(s): CTS
    Jul 2012
    N.E. OH
    722
    Re: TPMS Question
    I assume the OP is purchasing a wheel AND tire package
    Srsbisns's Avatar
    Oct 2013
    14
    Re: TPMS Question
    Quote Originally Posted by Mistercoffee2 View Post
    Yes i understand how the system works to that degree. My understanding is that my stock rims have the sensor inside which the receiver in the car uses to determine the pressure. My question is if i take off the stock rim and tires with the sensors still inside and put them in my basement then when i switch to winter tires with just the standard black steelie rims with no sensor inside my sensor light in my car will go off and i wont be able to go into competitive mode or change traction settings for getting out of deeper snow etc since the receiver in the car will not get a signal from the sensors which will be in my basement. Now based on the article i previously referenced from my understanding once the sensor and receiver are out of far enough range of eachother the system will disable and i won't have to worry about the tpms warning coming up on my dash and can then switch my modes like previously before. I'm just trying to determine if i understood that article correctly so i don't have to waste more money getting another set of sensors for my winter tires or just deal with the warning on my dash all winter.
    The_Judge's Avatar
    The_Judge is offline Cadillac Owners Connoisseur
    Automobile(s): '11 CTS 3.6 Premium, Black on Black, 19" Summer Tire Package
    Jun 2008
    Hermosa Beach, California
    1,523
    Re: TPMS Question
    The TPMS has saved me from damaging tires on my CTS on two occasions that I got a puncture and again when one developed a slow leak. If they're not terribly expensive, I'd suggest that you get a set for your winter tires and rims. Of course, if you prefer to change a flat in a blizzard...
    Mar 2012
    Houston TX
    516
    Re: TPMS Question
    Quote Originally Posted by 99flhr View Post
    Living in Texas, I would never have guessed that from OP.
    hauler's Avatar
    hauler is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 Sportwagon 18.2city 28hwy 25hwy AC on
    Nov 2012
    Moline,IL
    531
    Re: TPMS Question
    Tpms valves are $40 each on Amazon
    Mar 2012
    Houston TX
    516
    Re: TPMS Question
    Quote Originally Posted by The_Judge View Post
    At <$50 each, maybe that is the $200 the OP referred to.
    As to the TPMS disabling, I can only say that with one missing sensor it continue to set a code. Not sure if all sensors are missing. No mention of this happening in the Service Manual.
    The_Judge's Avatar
    Jun 2008
    1,523
    Re: TPMS Question
    GM ACDelco OEM TPMS units are only $30 each on Amazon, free shipping:
    http://www.amazon.com/ACDelco-135863...2138495&sr=1-1
    Srsbisns's Avatar
    Oct 2013
    14
    Re: TPMS Question
    I appreciate all the reply's and concern for my winter safety but still looking for the answer to my original inquiry based on the link i provided in the original post. I wish i could take advantage of amazon.com savings but once it gets past the Canadian boarder i get destroyed by taxes and it would even out to going to the dealership unfortunately. I'm not too terribly worried about having the tp sensors since this is the first car i have owned that has even had them and i have had no issues in the past (knock on wood), my main concern is the tpms warning and having to deal with it. Once again thank you all for the replies so far.
    Automobile(s): CTS
    Jul 2012
    N.E. OH
    722
    Re: TPMS Question
    I have non GM car with winter tires with no sensors, if I move the summer tires "out of range" (basement) the warning light stays on all winter.
    If I store the summer wheels near the car, ( garage) the light stays off for trips of 30 min or less.
    Could you share the interchange # for steelies that fit CTS ?
    Thank you
    Srsbisns's Avatar
    Oct 2013
    14
    Re: TPMS Question
    Thank you
    My stock rims are 18"s but for winter i'm dropping down to 17" the steelie interchange # is X43754 and the tire size i will be running is 235/55/17
    99flhr likes this.
    hauler's Avatar
    Nov 2012
    Moline,IL
    531
    Re: TPMS Question
    Do you pick the tire size and aspect ratio to get the same OD, or can you correct the speedometer for another OD?
  16. #14
    Srsbisns's Avatar
    Oct 2013
    14
    Re: TPMS Question
    Quote Originally Posted by hauler View Post
    You can get the speedo corrected through the dealer depending on how off it is based on the new tire.
    i use this site to determine how much my speedo reading will be off by http://www.miata.net/garage/tirecalc.html and just account for it myself. In this case my speedo will be showing 60mph but i will really be going 59.8mph which isn't that significant of a difference to require me to go to the dealer to correct, especially since i will be swapping back to the 18"s once winter passes.
    Only reason i chose to go down to 17"s for winter tires is because 18" snow tires cost an arm and a leg in comparison.
    My tire size on my 18"s is 235/50/17
  17. #15
    Citabria's Avatar
    Citabria is offline Cadillac Owners Member
    Automobile(s): CTS
    Oct 2012
    Post Falls Idaho
    86
    GM ACDelco OEM TPMS units are only $30 each on Amazon, free shipping: http://www.amazon.com/ACDelco-135863...2138495&sr=1-1
    Thanks Judge,
    Saved me a bunch of money, just ordered a set of 4!
    Greg
  18. Remove Advertisements
