black smoke
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By conedoctor
2008-2013 Cadillac CTS General Discussion Discussion, black smoke in Cadillac CTS Second Generation Forum - 2008-2013; Do all DI engines blow black smoke when you are flooring the gas pedal?...
    dklswh is offline Cadillac Owners Member
    Automobile(s): 2008 CTS4
    Oct 2011
    53
    29
    black smoke
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,779
    Re: black smoke
    If it only lasts a second or two and doesn't happen every time you accelerate then; you are most likely blowing out any accumulated carbon in the exhaust system and mufflers. If it happens every time you punch it and it lasts more than just a few seconds check your oil for any excessive usage, the black smoke you see could be oil burning off.
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,622
    Re: black smoke
    Black is usually poor combustion, it should not blow tons of black smoke and if it is then some fuel is not being burnt fully. As said above it may do it for a second when you stand on it but the smoke should not continue, maybe tune up time.
    99flhr likes this.
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,731
    Re: black smoke
    Maybe you need an Italian Tune-up a little more often.
    dhtigerfan's Avatar
    dhtigerfan is offline Cadillac Owners Member
    Automobile(s): 2011 Cadillac CTS Coupe
    Oct 2012
    Jenison, Michigan
    75
    25
    Re: black smoke
    Quote Originally Posted by dklswh View Post
    Mine certainly doesn't.
    Joe
    Joe is offline Cadillac Owners Fanatic
    Automobile(s): 08 CTS blk/blk
    Jul 2010
    MA
    68
    383
    Re: black smoke
    Hey dklswh,
    How often are you adding oil? Most of these engines use a little oil, because of rings, seals, guides or all of the above. How many miles on the vehicle?
    Oct 2011
    53
    29
    Re: black smoke
    oil has never been down, i use synthetic, premium fuel sometime. it is not big clouds of smoke just noticeable. Car has 170000 km (106,000 mi) plugs just replaced, guess i'll keep an eye on it.
    Thanks
    Joe
    Jul 2010
    MA
    68
    383
    Re: black smoke
    Hi dklswh,
    If you are not using oil you are way ahead of the game. Mine throws a little smoke when I punch it. Its probably carbon like C "T"ess mentioned. I do have a feeling these engines being direct injected probably push a lot of fuel into the cylinders when we get on it. I suspect also many of these high horsepower engines just cant burn it up quick enough so it gets tossed un-burned out of the tailpipe. How's your gas mileage?
    99flhr is offline Cadillac Owners Enthusiast
    Automobile(s): CTS
    Jul 2012
    N.E. OH
    722
    Re: black smoke
    Conventional wisdom is that oil smoke is blue/white.
    Sep 2007
    2,622
    Re: black smoke
    They only push as much fuel into the cylinders as called for they just do it a bit better.
    I think mine does it but I never get a chance to floor it
    reciprocity is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V (red), 2009 CTS Premium Sedan (red), 2016 ELR (Radiant Silver Metallic)
    Jan 2005
    California
    343
    Re: black smoke
    I think C"T"ess is right. If I really accelerate hard (getting on the freeway from a metering light on a short onramp, for example), I definitely notice a small "cloud" of carbon. I'm pretty sure that's what it is if it's only under heavy acceleration. Just keep an eye on your oil consumption and you should be fine.
    sliderule01 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS Wagon
    Dec 2011
    208
    Re: black smoke
    I get the same thing. Most of my driving is in town. I do notice it more when I use regular and not premium. When I hit the pedal hard during a passing situation, I get an occasional puff of black smoke. It is not blue which suggests oil. This usually happens when I floor it quickly to pass and I get a rapid kickdown on the transmission to pass. I suspect that it is carbon build-up and I need to do an "Italian tune-up" more often.
    While people say that the use of premium is not necessary, I have documented that I do get a couple of miles per gallon better with premium with the same sort of driving by alternating tanks, and approximately 10 tanks each. I see the same thing when driving the same route on the highway with the cruise control set to the same speed. While not a big statistical sample, it is strongly suggestive.
    tinman's Avatar
    Jul 2006
    9,731
    Re: black smoke
    Quote Originally Posted by sliderule01 View Post
    Interesting with your mpg. Does the extra mpg "pay" for itself with the additional cost of premium?
    GO TIGERS! (and Red Wings)
  16. #14
    C&C's Avatar
    C&C
    C&C is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,976
    Re: black smoke
    There is no more energy in a gallon of premium than there is in a gallon of regular; however, if you do have some of that carbon buildup (and it is in the area of combustion) you engine may be identifying some 'ping' (with regular) and is retarding the timing a bit (lowering your mpg). Premium may in fact give some better mileage figures. I do doubt that you are saving any money (using premium) as the cost difference would negate any differences of mileage versus cost. Top-tier gasoline and an occasional engine exercise (i.e. Italian tuneup) should relegate premium to cars that call for it.
  17. Remove Advertisements
