Automatic--->manual transmission swap, possible?
Results 1 to 15 of 15
Like Tree6Likes
  • 1 Post By MotownPimp
  • 2 Post By C "T" ess
  • 3 Post By joekitch
2008-2013 Cadillac CTS General Discussion Discussion, Automatic--->manual transmission swap, possible? in Cadillac CTS Second Generation Forum - 2008-2013; as far as i know, there really isn't much mechanical difference between the auto and manual transmission versions of the ...
    joekitch's Avatar
    joekitch is offline Cadillac Owners Fanatic
    Sep 2013
    26
    198
    as far as i know, there really isn't much mechanical difference between the auto and manual transmission versions of the CTS, since GM is cheap and likes to re-use everything.
    to that end, would it be (relatively) simple to stick the CTS manual transmission into an automatic CTS? are there significant differences in mounting/electronics/driveshaft attachment that prevent this from happening?
    this is assuming i'm using the RWD automatic for the swap
    MotownPimp's Avatar
    MotownPimp is offline Cadillac Owners Connoisseur
    Automobile(s): CTS Coupe Performance Stick
    Jan 2011
    Northern California
    74
    1,001
    Re: Automatic--->manual transmission swap, possible?
    Black'10CTS4 likes this.
    joekitch's Avatar
    Sep 2013
    26
    198
    well, historically, swapping manual trannies into automatic cars that came with a manual option isn't that difficult....as far as transmission swaps go
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    That was before the age of computers. I believe that, wiring harnesses, and mounting points and drive shaft will make this project a no go. You would probably be better off finding a MT and trading.
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    8,741
    Jeezus, why? Just go out and buy one from the factory. No bugs, warranty, and it works.
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Lets face it, yes you could do it, if you have the time and money then rock on but I think to most it is just not worth it.
    arachnyd is offline Cadillac Owners Member
    Automobile(s): CTS
    Sep 2013
    91
    It may not be as expensive as you think, however, manuals are much much cheaper than autos, so frankly, why spend $5k on a swap when You can drop your auto and pick up a manual and make $5k?
    CTSCHICK Guest
    My b.f. does auto to manual and manual to auto swaps on cars so I end up having order his parts.
    There is a lot more to it than just swapping transmissions.
    Pcm has to be re-flashed for a manual including matching the vin# , reverse switch, clutch switch wiring, sometimes trans mounts and cross members, pedal assemblies, master/slave cylinder, clutch, pilot bearings ect,ect.
    I forget what else.
    joekitch's Avatar
    Sep 2013
    26
    198
    Quote Originally Posted by CTSCHICK View Post
    I forget what else.
    well, yeah. that's true for all tranny swaps
    but some are much harder than others due to wildly different mounting, hookups, ect.
    99flhr is offline Cadillac Owners Enthusiast
    Automobile(s): CTS
    Jul 2012
    N.E. OH
    722
    I would rather have a root canal and a colonoscopy on the same day than make this swap. JMO Good luck with your project.
    Sep 2007
    2,621
    I would think it would also kill the resale value for the average buyer, even if done right if people pull the Vin and see it is an auto questions will be asked.
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,773
    Quote Originally Posted by 99flhr View Post
    On the same day; I'd really have to think about that one.
    99flhr and EVH5150 like this.
    joekitch's Avatar
    Sep 2013
    26
    198
    Quote Originally Posted by C "T" ess View Post
    Tune up at both ends
    tinman, C "T" ess and EVH5150 like this.
  16. #14
    EVH5150's Avatar
    EVH5150 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Coupe Premium: RWD, FE3 Suspension, 6-speed manual
    Apr 2013
    Somewhere in Canada LOL!!!
    38
    321
    LOL!
    Nothing like a good clean ass hole!
    Quote Originally Posted by joekitch View Post
    LOL!
    That's what I'll say to my wife; "Baby I think I'll give you a tune up at both ends". Wink, wink.
  17. #15
    AlpineCTS is offline Cadillac Owners Member
    Apr 2013
    78
    Quote Originally Posted by arachnyd View Post
    I dont get where the 5k quote comes from i spotted a couple ay6 aisin manual 6 speed trannys for like 600-1000 near me in several yards with like 50-60k miles. i figured it would be pretty easy to get most of the parts between a donor car or 2..... i may do this. If i did and disabled the governor cutout and a diff swap ill be set.
  18. Remove Advertisements
