Page 1 of 4 1234 LastLast
Results 1 to 15 of 60
Thread: Help! How to find 12v power in center stack
    dlpuette's Avatar
    dlpuette is offline Cadillac Owners Fanatic
    Automobile(s): 2013 AWD Performance Coupe, 2011 Harley ElectraGlide Limited
    Aug 2013
    Cleveland, Ohio
    122
    I'm a new Coupe owner (13 Performance - no nav) and want to mount my Garmin on the panel that would normally be the roof of the slide up nav. I popped the cover and there's Texas size space back there and the panel will make an easy mounting, but the space behind there is all pretty sealed up. I know the fuse box is on the engine side of the firewall and don't want to go there. I'm sure there's something in the center stack that I can tap some 12v power from. I just don't know how to get there. Has anyone ever popped the faceplate off the stack? If so, what's the trick? Or any other way to get some 12v?
    This is my first ever GM product (BMW's mostly before this) and I'm not familiar with how they button panels down. Are they just carefully pry off? Or are there hidden fasteners? Don't want to F** up my interior pieces trying to pry something off that isn't meant to be.
    I always had tremendous luck in the BMW forums with helpful members. Hoping my foray into the Caddy world is just as good!!
    Thanks for any help!!
    Sal33n's Avatar
    Sal33n is offline Cadillac Owners Fanatic
    Automobile(s): Former '03 CTS owner, 09' CTS4
    Apr 2008
    Ray, MI
    48
    109
    Re: Help! How to find 12v power in center stack
    I would like to know how you popped that cover off as I also though about making some sort of mount in there and assumed there would be space inside there. I have been hesitant because I don't want to break that cover trying to pry it off.
    dlpuette's Avatar
    Aug 2013
    Cleveland, Ohio
    122
    I just wiggled it straight up. There's tons of space behind the LCD!!! But whatever you're mounting there will need power and thats my dilema.
  5. #4
    hauler's Avatar
    hauler is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 Sportwagon 18.2city 28hwy 25hwy AC on
    Nov 2012
    Moline,IL
    531
    12volt power (switched) for the console APOs is the red wire in the connector that you see when you pull the passenger side carpet down from the console. That's the wire I used to connect both my detector and my back up sensor. APO is what's on the fuse block diagram for Aux Power Outlets
  6. #5
    dlpuette's Avatar
    Aug 2013
    Cleveland, Ohio
    122
    Hauler
    Thanks for the reply!! That could work! Could you be a bit more specific about where on the console yo pull the carpet? Any tricks in pulling it down without damage?
    Thanks again!!
  7. #6
    hauler's Avatar
    Nov 2012
    Moline,IL
    531
    Pull the pass side carpet from under the console cover. It will tuck back in. The harness is running along the floor just below the edge of the cover. I pulled the white connector apart and peeled back the harness wrap a little to access the red wire with a splice connector used for trailer wiring additions.
  8. #7
    dlpuette's Avatar
    Aug 2013
    Cleveland, Ohio
    122
    Outstanding! Thanks hauler!!!
  9. #8
    dlpuette's Avatar
    Aug 2013
    Cleveland, Ohio
    122
    Hate to say it,but there may be a difference in the harnesses for your wagon and my coupe. Pulled back the carpet and there is some bigger connectors directly under the dash that run down to the floor and to the power seat and one up into the center console between the seats. But no white connector in sight. The one that goes to the center console disappears into it.
    The bigger connectors under the dash could be my best bet, but figuring out which is switched power will be interesting. I'll stick a grounded volt meter on the likely ones and see if I can find 12v. Hate not knowing what else it's feeding before I go loading it more with the GPS.
  10. #9
    dlpuette's Avatar
    Aug 2013
    Cleveland, Ohio
    122
    Maybe someone here knows those connectors?
  11. #10
    RAB's Avatar
    RAB is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS Premium AWD Sport Sedan w/FE5 - RadiantSilver|Ebony
    Jun 2007
    Ontario, Canada
    2,108
    ^ dlpuette.. I've checked the service manual schematics for the 2013 CTS (for Sedan, Coupe and Wagon). The 12V power outlet at the base of the center stack at the top end of the center console is known as the Cigar/Cigarette Lighter Receptacle-Front. The wires that feed this receptacle (as well as the two other 12V accessory power receptacles located further back in the center console) are color-coded as:
    a) RD/WH (Red/White) colored wire for the +12V feed (i.e. which is a switched "+" power feed coming from the Accessory Power Relay)
    b) BK (Black) colored wire for the -12V feed
    The key is.. look for a wire that is jacket color coded red/white - that's the switched +12V feed to all the accessory power receptacles in the CTS Coupe. The black colored wire(s) in a given power wiring harness represents -12V (negative 12V). Hope this helps.
  12. #11
    dlpuette's Avatar
    Aug 2013
    Cleveland, Ohio
    122
    RAB
    Thats fantastic info! Any idea where that connector that feeds those wires is? When I pulled the carpet back on the passenger side there are two fairly big connectors coming down from the side of the center stack. Is it possible that those wires you mentioned are in one of those connectors? Maybe the service manual mentions the connector locations. I'll def look for any R/W wires heading that way and check em with a meter.
    Either way, thank you VERY much for taking the time to look that up for me!!!
  13. #12
    hauler's Avatar
    Nov 2012
    Moline,IL
    531
    One connector has the wire. If your car has a power passenger seat (mine doesn't) that's the other connector. Disconnect one and see if the console outlets stop working.
  14. #13
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    As an alternative to consider, I made a bracket for my TomTom. It fits securely in the opening that would have been for the ashtray. A short USB cord connect the power to the cigarette lighter. It works great, there is no degregation of the signal and it makes it almost appear as built into the dash.
  15. #14
    hauler's Avatar
    Nov 2012
    Moline,IL
    531
    I use a plastic disk on the dash radio screen to suction mount my GPS, then put it back in the console until I'm on another road trip, just to keep my car from being broken-into. Last month it was in a park while my wife and I bicycled down a bike path. The Lexus parked next to my wagon got a broken window for access to its GPS, but my car was unharmed.
  16. #15
    dlpuette's Avatar
    Aug 2013
    Cleveland, Ohio
    122
    Thanks guys for all the input!! I'm gonna tackle this over the weekend. I'll post back how it goes!
    Hauler - I'm curious about the placement of that plastic disc. I thought about putting one somewhere in the middle of the dash to keep using the suction mount, but couldn't find an area big enough that's flat to put one. What do you mean by the radio screen? Mine is only about 1 1/2" tall (if you mean the non-nav LCD screen at the top of the stack.
  • You may not post replies
