help with trunk wiring
Results 1 to 4 of 4
2008-2013 Cadillac CTS General Discussion Discussion, help with trunk wiring in Cadillac CTS Second Generation Forum - 2008-2013; I am reposting from the V forum. Need some help. Bought a license plate frame that will help me avoid ...
    simgolfer's Avatar
    simgolfer is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-V sedan, manual, silver/ebony, airaid, SW catback
    Jul 2011
    Elk Grove, CA
    228
    Need some help. Bought a license plate frame that will help me avoid big brother capitalism otherwise known as red light cameras operated by big foreign corporations. (check out nophoto.com) Anyway I need to figure out how best to get a wire from the license plate area into the trunk so I can hook it up (live wire and ground). Is there a good hole underneath the chrome trunk trim I can access? Is there wiring in the trunk I can easily splice into? Thanks.
    Michael
    Tbbt is online now Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,131
    Re: help with trunk wiring
    Couldn't you just tap into the license plate bulb wiring?
    I know nothing about these frames, so maybe I'm just off base. You're talking about the rear plate, right?
    Marv
    simgolfer's Avatar
    Jul 2011
    Elk Grove, CA
    228
    Yeah rear license plate frame. I would like to tap into the license plate lights but trying to figure out where I can get a wire in without crimping it and damaging it. Thanks for the reply.
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Just pull out one of the license plate lamps (they just snap in) pull out the wiring;do your splicing, push everything back together and you should be good to go.
    Other than that, driving responsibly could also avoid your problem.
  7. Remove Advertisements
