I drive so fast my clear coat Is peeling off!!! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Like Tree2Likes
2008-2013 Cadillac CTS General Discussion Discussion, I drive so fast my clear coat Is peeling off!!! in Cadillac CTS Second Generation Forum - 2008-2013; Originally Posted by cadsmeow6 By the way, you can't drive fast enough to make paint peel. that only happens in ...
  1. #16
    HurstGN is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,904
    Re: I drive so fast my clear coat Is peeling off!!!
    Quote Originally Posted by cadsmeow6 View Post
    By the way, you can't drive fast enough to make paint peel. that only happens in TV commercials.
    But I have seen a car drive fast enough to peel off a vehicle wrap. Happened to Tim Wilkerson's Funny Car when he was running the Circle K colors in Michigan. I guess 300 mph can do that.
  2. #17
    BlueAngel#07's Avatar
    BlueAngel#07 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 DTS PERFORMANCE
    Feb 2013
    Minnesota
    1,113
    That would f@$&!n freak me out!
    That isn't something that you you can let go for long, once the clear starts peeling.... It's a disease, as you know your clear is your only protection from screwing up your paint further,
    Peeling usually happens to darker color cars as a result of heat build up over time and eventually breaks down the elements of the undercoat which works its way up. Yours looks suspect.. Like dealer special( quick paint to sell it job). Hope it's under warranty, that has to go down to the primer to fix it if done right. Looks like it would be cheaper to paint the whole thing, BTW nobody would frown on new paint unless it wasn't done right! Good luck
  3. #18
    Gerry1946 is offline Cadillac Owners Member
    Automobile(s): CTS Coupe
    Aug 2013
    Racine, WI
    39
    Throw it in reverse and drive equally fast. The clear coat should redeposit on the car.
    Sorry, I could not resist.
    C "T" ess and mnmjack like this.
  5. #19
    Aug 2013
    Racine, WI
    39
    My 2013 CTS Coupe was repainted due to acid rain spots on the hood and top. Dealer did a beautiful job. I believe it looks better than factory.
  6. Remove Advertisements
