Front Wheel Bearing
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Like Tree1Likes
2008-2013 Cadillac CTS General Discussion Discussion, Front Wheel Bearing in Cadillac CTS Second Generation Forum - 2008-2013; Hello, Can someone tell me what part I need to replace the front passenger side wheel bearing. Do I need ...
    jhschlak is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS 3.6 DI
    Aug 2006
    125
    Front Wheel Bearing
    Hello,
    Can someone tell me what part I need to replace the front passenger side wheel bearing. Do I need an entire front wheel hub? Or can I just replace the bearings themselves? I have 2009 DI RWD.
    If anyone has a link that shows how or gives instructions on how to replace, I would really appreciate it.
    Had 2 replaced under warranty, now I think I hear number 3. I am getting good at diagnosing this one!
    Thanks,
    Jeff
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Re: Front Wheel Bearing
    You should be able to just pull the disc and remove the bearings and replace with new ones. I would do inner and outer at the same time just to me safe. Be sure to grease them up good before installing the new. I would also check your alignment, there is no way you should be going through so many bearings. You may want to consider changing out the disc as well.
    CTSCHICK Guest
    You have to replace the entire hub it is an all in one unit with the bearings in the housing.
    Aug 2006
    125
    Thanks CTSCHICK!
    I had a feeling it was all one unit. I think I like that idea better anyway, I don't think I would be comfortable greasing the bearings and reinstalling etc. I am seeing a price of over $200.00 for the part, yikes. I imagine this is a $500.00 + fix at the dealer.
    I baby this thing like you wouldn't believe. I know which lanes have the bumps/potholes to and from work and methodically miss them every day. I can't believe I have another one going bad. Not impressed.
    Jeff
    CTSCHICK Guest
    Yeh unfortunately I have had the same problem with a different GM vehicle that went through 5 GM hubs
    Once it was out of warranty I always went with a Timken hub and never had the problem again
    Twentybucks is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS AWD Luxury Black Raven
    Feb 2013
    Cape Cod, MA
    60
    193
    Quote Originally Posted by jhschlak View Post
    Thanks CTSCHICK!
    Jeff
    I'm not too surprised, GM has had problems with front wheel bearings across all models and lines for some years now. I had to replace the front wheel bearing hub assembly on my Suburban at 110K. The drivers side was bad but since I had all the tools out I replaced both sides with the American made MOOG assemblies. The MOOG's had a three year warranty as opposed the cheaper Chinese made with a 1 year warranty. The MOOG's were about $190 each and the made in China assemblies were $90. The assemblies for my burb were expensive because they have the wheel speed sensor built right into the assembly. The speed sensors send a signal to the ABS braking system. I did both sides for under $500, the dealer would have likely charged around $1,200 to do both sides. It only took me 4 hours to complete both sides.
    Aug 2006
    125
    I think the hub that I saw was an AC Delco. If that is what is on it now, then I definitely don't want to replace it with that.
    CTSCHICK Guest
    Check RockAuto
    Tbbt is online now Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,124
    How long ago was the 'going bad' one replaced? There should be a 12 month warranty on replaced parts.
    Good Luck, Marv
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,674
    Thanks CTSCHICK!
    Jeff
    Hello Jeff,
    I apologize for any trouble you are experiencing with your wheel bearing. If you would like to further discuss this with me, please reach out via private message and include your VIN and mileage, also the name and location of the dealer you have previously worked with. I would like to help look into this for you.
    Sincerely,
    Laura M.
    Cadillac Customer Care
    Feb 2013
    Cape Cod, MA
    60
    193
    I bought the MOOG's from Advanced Auto Parts. You might want to look at the Timken wheel bearing assembly at 1AAuto.com they are about $500 for the pair, they come as a pair so you might as well replace both if you are going to do them yourself.
    Mistercoffee2's Avatar
    Mistercoffee2 is offline Cadillac Owners Enthusiast
    Mar 2012
    Houston TX
    516
    Quote Originally Posted by C "T" ess View Post
    Dude, are you OLD SCHOOL! Me too.
    Hello,
    Thanks,
    Jeff
    $213.74 free shipping on Amazon. Less then an hour in your driveway (RWD). Remove wheel, 1 screw, 5 bolts and do it again in reverse. No bearing grease on your hands.
    Aug 2006
    125
    I'm seeing a Timken hub on amazon for 135.00. I think they are a good name, especially for bearings, right?
    http://www.amazon.com/Timken-HA59026...2009+wheel+hub
  16. #14
    Aug 2012
    Castle Pines, CO
    73
    2,124
    Quality company, good products, great price.
    So, how long ago did Cadillac replace it under warranty?
    Marv
  17. #15
    Aug 2006
    125
    I had the driver side front done in June '11 and the driver side rear in June '12. This one is the passenger side front.
  18. Remove Advertisements
