Front Wheel Bearing - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
Like Tree1Likes
2008-2013 Cadillac CTS General Discussion Discussion, Front Wheel Bearing in Cadillac CTS Second Generation Forum - 2008-2013; Originally Posted by CTS4MATION Just an update. Got the wheel bearing in today, boy is it nice to drive and ...
  1. #31
    jhschlak is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS 3.6 DI
    Aug 2006
    124
    Re: Front Wheel Bearing
    Quote Originally Posted by CTS4MATION View Post
    Just an update. Got the wheel bearing in today, boy is it nice to drive and have the capability to talk to the person sitting next to you haha.
    The hub assembly was cake to put on. The only problem I ran into was getting the old hub off. I beat my brains out for 2 hours with 2 hammers swingin to get it off. Good lord was that thing seized on. When it finally did come off I spent about 45 minutes scrapping out tons of road grime which most of it was OLD salt that caked together and formed a cement like seal around it.
    Other than that it was simple.
    So you bought the Timken Hub from amazon then? Were the bolts seized or was it the hub itself that was seized after you took them off? I wonder if there is any type of puller that could be rented from an autostore to help with this?
    Thanks,
    Jeff
  2. #32
    CTSCHICK Guest
    You can use a puller on the rear, the front since you aren't AWD is just 3 bolts
  3. #33
    Tri-SS's Avatar
    Tri-SS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V, 2011 CTS-V
    Feb 2008
    Southern Ontario, Canada
    168
    Left rear wheel bearing went bad on my '10 RWD this week at 42,000 miles. Dealer is changing it today under warranty. Should both sides be changed as a rule or is one ok?
  5. #34
    CTS4MATION is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS4
    Jun 2012
    PA
    155
    Quote Originally Posted by jhschlak View Post
    Thanks,
    Jeff
    Yea I bought the timken.... The bolts came right out with no problem. It took me I'd say 20 minutes from putting the car in the garage to "ok im ready to yank the hub out". The hub was stuck big time, but nothing a BFH couldnt fix..... well in this case 2. HAHA yea a puller would have been nice for this! I finally have a garage built so now Im in tool buying mode...... pullers and a slide hammer are top on the must have list!
    Quote Originally Posted by Tri-SS View Post
    Really!?..... darn coulda got mine for free, ohh well. Im just tired of taking off work to go to the shop..... If you want warranty work, they're only going to give you 1 for free unless the other is bad. As a rule of thumb most would say "if its not broke dont fix it".
  6. #35
    Xtant12's Avatar
    Xtant12 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS-AWD DI ( Hot Lava Edition )
    Oct 2012
    Island Lake IL
    33
    123
    FYI'S
    The bolt to get the hub nut off is a 36MM
    I use a long truck prybar between to of the studs and the ground to prevent the hub from moving.
    Also for the three 13MM bolts in the back its works out best if you turn the wheel to get them out.
    Just a few things I learned today!!
  7. #36
    Aug 2006
    124
    Hey guys,
    Do you know if GM used loc-tite on any of the hub bolts? My buddy is telling me I will need to use heat
    to get them off. I have never applied heat to any bolts for fear of ruining something!
    Xtant12 can you describe this in more detail if possible: I use a long truck prybar between to of the studs and the ground to prevent the hub from moving.
    I can't seem to visualize how you locked the hub down to prevent from moving.
    Thanks!
    Jeff
  8. #37
    99flhr is offline Cadillac Owners Enthusiast
    Automobile(s): CTS
    Jul 2012
    N.E. OH
    722
    ^ He`s telling you to put the prybar parallel against the hub with one end on the ground, when you rotate the hub nut, the hub will turn only until the wheel studs jamb against the bar. Hub stops turning, nut comes off
    Visualize a yard stick placed flat across the face of a wall clock ( the #`s are the studs) The stick crosses the face diagonally under 8 & 2.
    When you spin the face CCW, the bar hits 8 and 3
  9. Remove Advertisements
