Disable TPMS
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Like Tree4Likes
2008-2013 Cadillac CTS General Discussion Discussion, Disable TPMS in Cadillac CTS Second Generation Forum - 2008-2013; Any way to get this light off my dash? Pull a fuse? Disconnect a wire? Remove the bulb from the ...
    dugunz is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2008
    35
    192
    Disable TPMS
    Any way to get this light off my dash? Pull a fuse? Disconnect a wire? Remove the bulb from the cluster? I have aftermarket wheels and I hate that light... I have searched the forums and I can't find anything on the 08+... Any suggestions?
    gohawks63's Avatar
    gohawks63 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Black Diamond CTS-V Coupe
    Feb 2008
    54
    3,350
    Re: Disable TPMS
    Not sure about the ability to disable the light.
    Why didn't you just move the TPMS sensors to the new wheels? That's what I did when I got new wheels for my coupe?
    Nov 2008
    35
    192
    Re: Disable TPMS
    Quote Originally Posted by gohawks63 View Post
    I bought the car with aftermarket wheels and I don't have the factory wheels.
    Tbbt is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,359
    Re: Disable TPMS
    All new auto's sold in the US starting with Model Year 2007 were required to have TPMS as standard equipment.
    Even though they do a good job of letting you know when you have a low tire, they can be VERY annoying when the weather changes to colder. They are very sensitive to pressure changes.
    Try a piece of tape?
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Disable TPMS
    the TPMS sensors sense pressure changes - that's their job
    the moisture in the air in your tires changes the pressure as the temp changes
    fill with nitrogen and don't worry about the pressure changes so much
    some places overcharge for the nitrogen fills so shop around
    we offer a road hazard insurance with our nitrogen fill (pays up to $150 per tire) so it's worth the $40 we charge
    also, TMPS is considered a safety item so there's not really an easy/legal/smart way to disable
    similar to wanting to disable your AirBag light because you got a new steering wheel that doesn't have an airbag in it
    obviously it's your car and you can do whatever you want with it but GM isn't going to expend extra resources to help anyone circumvent any of the systems in the car
    especially any of the safety related systems
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,321
    Re: Disable TPMS
    You can always buy tpms from people like Rippy Cadillac (contact Chris above). That should cure your problem.
    fps_dean is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS 3.6 DI AWD
    Jul 2009
    North Adams, MA
    35
    242
    Re: Disable TPMS
    Quote Originally Posted by Tbbt View Post
    I have to replace one every few years. And when it's below 50-55 out, at least one of them will act up even if I just replaced all 4! It's insane! If I could disable it, I would
    99flhr likes this.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,263
    Re: Disable TPMS
    I don't start having trouble with TPMS until temps get down to -20F or lower. You can save yourself a lot of headaches by filing your tires with dry air or dry nitrogen. The average tire shop or garage gives you a shot of water everytime you use their airhose even if they drain the tank on their compressor.
    Don't mess with Binky Bear!
    The_Judge's Avatar
    The_Judge is offline Cadillac Owners Connoisseur
    Automobile(s): '11 CTS 3.6 Premium, Black on Black, 19" Summer Tire Package
    Jun 2008
    Hermosa Beach, California
    1,526
    Re: Disable TPMS
    TPMS works, and I wouldn't want a car without it. It's not terribly accurate, but on two occasions it's saved me from possibly damaging or even destroying a tire by warning me via a message on the DIC that a specific tire had lost a significant amount of pressure. Both times that turned out to be due to a screw that had punctured the tread. It's a very convenient and clean way to check your pressure, too, much better than simply eyeballing the tires and faster and a lot cleaner than manually checking each one. I'm looking forward to the next step in tire management, which will be automatic filling of the tires to keep them at a user-defined minimum setting.
    tinman's Avatar
    Jul 2006
    9,321
    Re: Disable TPMS
    Judge, you can't beat manually checking each one. I do at a minimum every other month. I am surprised how much they vary after a couple of months.
    That being said, I do agree that the tpms is a good thing (thanks, Firestone and Ford).
    The_Judge's Avatar
    Jun 2008
    1,526
    Re: Disable TPMS
    Quote Originally Posted by tinman View Post
    I agree completely. In fact, I'm something of a fanatic about it, checking my tire pressure with the TPMS every few days (they lose a pound every week or so) and manually checking the tires and adding air every few weeks, especially if the TPMS indicates a drop below 35 PSI in any of the tires when they're cold. And I usually add an extra two pounds of pressure to each tire -- better handling, IMHO, and an extra margin of protection. I have a couple of excellent tire pressure gauges and a Black & Decker air pump at home:
    http://www.amazon.com/Black-Decker-A...=air+pump+tire
    tinman's Avatar
    Jul 2006
    9,321
    Re: Disable TPMS
    Interesting, as I run at 37 psi, too.
    The_Judge's Avatar
    Jun 2008
    1,526
    Re: Disable TPMS
  16. #14
    tinman's Avatar
    Jul 2006
    9,321
    Re: Disable TPMS
    lol!
  17. #15
    mcneill8328's Avatar
    mcneill8328 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Coupe, Premium Pkg
    May 2012
    Cleveland, OH
    280
    Your tires lose a pound every week? That sounds like a problem to me.
  18. Remove Advertisements
