Disable TPMS - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 31
Like Tree4Likes
2008-2013 Cadillac CTS General Discussion Discussion, Disable TPMS in Cadillac CTS Second Generation Forum - 2008-2013; Originally Posted by mcneill8328 Your tires lose a pound every week? That sounds like a problem to me. Sloppy writing ...
  1. #16
    The_Judge's Avatar
    The_Judge is offline Cadillac Owners Connoisseur
    Automobile(s): '11 CTS 3.6 Premium, Black on Black, 19" Summer Tire Package
    Jun 2008
    Hermosa Beach, California
    1,526
    Re: Disable TPMS
    Quote Originally Posted by mcneill8328 View Post
    Sloppy writing -- should have said "loses a pound every few weeks." Not a problem, just pretty much normal in my experience.
  2. #17
    MattM23 is offline Cadillac Owners Member
    Automobile(s): 2009 CTS 3.6 DI
    May 2013
    30
    15
    Re: Disable TPMS
    my TPMS system seems to be off from my actual readings from a tire pressure gauge any suggestions?
  3. #18
    The_Judge's Avatar
    Jun 2008
    1,526
    Re: Disable TPMS
    What sort of pressure gauge do you have? Cheapies are notoriously "approximate."
    Consider one of these: http://www.getagauge.com/
  5. #19
    May 2013
    30
    15
    Re: Disable TPMS
    yea I use cheapies lol
  6. #20
    CTSCHICK Guest
    Re: Disable TPMS
    Quote Originally Posted by The_Judge View Post
    They are the OEM for some of the Snap On Tools tire gauges
  7. #21
    hauler's Avatar
    hauler is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 Sportwagon 18.2city 28hwy 25hwy AC on
    Nov 2012
    Moline,IL
    531
    Re: Disable TPMS
    I have 3 or 4 cheap gauges, with a spread of 5 psi between them. As long as all 4 wheels come out the same and near 40 psi, I'm happy.
  8. #22
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,258
    Re: Disable TPMS
    40 psi is too high.
  9. #23
    hauler's Avatar
    Nov 2012
    Moline,IL
    531
    Re: Disable TPMS
    Well... I have always liked a car to ride hard, and I enjoy the slight added response and mileage, so I set them at about 90% of max pressure.
    Half a century ago, when I drag raced, I liked to say: Put a dime in the street. I'll run over it and tell you whether it's heads or tails.
  10. #24
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Disable TPMS
    that will wear out the center tread faster then the outer tread though
    and you're losing tread contact with the road (less traction overall)
  11. #25
    The_Judge's Avatar
    Jun 2008
    1,526
    Re: Disable TPMS
    Quote Originally Posted by tinman View Post
    40 psi is too high.
    Agreed, at least if that's measured when the tires are cold (i.e., they haven't been on the road for several hours, preferably overnight when the pressure is taken). I've found that when driving on the freeway at 70 MPH in normal daytime temperatures, the tire pressure will increase by 5 to 6 psi. If you start at 40, that means you'll be riding on 45 to 46 psi, which is way too high. And as pointed out by Rippy, it will cause the tires to wear unevenly, eventually causing a real safety problem.
  12. #26
    tinman's Avatar
    Jul 2006
    9,258
    Re: Disable TPMS
    As well as the fact when you are traveling at speed, your tires increase pressure. Depending on your tire, and maybe where it was manufactured (re: China or some other stinking third world country that has no standards), the maximum pressure for your tire may be exceeded. Blowout time.
  13. #27
    Mistercoffee2's Avatar
    Mistercoffee2 is offline Cadillac Owners Enthusiast
    Mar 2012
    Houston TX
    516
    Re: Disable TPMS
    I guess the OP has the answer to his question so I will just ask if anyone is using Nitrogen in their tires and how is it working out. I have read that it solves the problem of pressure loss due to seepage through the rubber.
  14. #28
    Sep 2007
    Wilmington, NC
    13,986
    Re: Disable TPMS
    i have been using nitrogen in my car for almost two years now and the only time i had to add air was when i had a nail in my tire
  15. #29
    The_Judge's Avatar
    Jun 2008
    1,526
    Re: Disable TPMS
    In my opinion, filling your tires with nitrogen is the automotive version of gluten-free food -- good in theory, perhaps, but a waste of money for most people. Or at least that's pretty much the conclusion of Edmunds:
    Is Nitrogen Worth It?
    The air we breathe is made up of 78 percent nitrogen, 21 percent oxygen and a few other elements. To get the desired benefits for tires, nitrogen needs to be at least 93 percent pure, according to nitrogen service equipment providers quoted on Tirerack.com. So we're basically talking about adding an extra 15 percent of nitrogen and getting rid of as much oxygen as possible. Based on cost, convenience and actual performance benefit, we don't think nitrogen is worth it. A much better use of your money would be to buy a good tire-pressure gauge and check your tires frequently. This is a good idea even if you have a tire-pressure monitoring system in your vehicle. The warning lights aren't required to come on until you have less than 25 percent of the recommended tire pressure. Having the correct tire pressure will get you many of the benefits of using nitrogen and will ensure that your tires last longer.
    Here's the link to the full article: http://www.edmunds.com/car-care/shou...-nitrogen.html
    TireRack.com comes to the same conclusion:
    So what should drivers do?
    Overall, inflating tires with nitrogen won't hurt them and may provide some minimal benefits.
    Is it worth it? If you go someplace that provides free nitrogen with new tires, why not? Additionally we’ve seen some service providers offering reasonable prices of about $5 per tire (including periodic adjustments for the life of the tire) to a less reasonable $10 per tire (with additional costs for subsequent pressure adjustments) or more as part of a service contract, which we believe exceeds the value of nitrogen’s benefit.
    Rather than pay extra for nitrogen, most drivers would be better off buying an accurate tire pressure gauge and checking and adjusting their tire pressures regularly.
    Here's the link:
    http://www.tirerack.com/tires/tirete...jsp?techid=191
    tinman, RAB and Tbbt like this.
  16. #30
    hauler's Avatar
    Nov 2012
    Moline,IL
    531
    Re: Disable TPMS
    Thanks, guys, for your concern. I understand the standard philosophy and reasons for running close to recommended pressure, and I appreciate all the advice. I do monitor the tires constantly. With tpms in my last 3 cars, I can monitor as I cruise on the highway.
    I usually push my car hard on corners and expressway ramps, so having the center of the tires wear out first hasn't ever happened to me. Since I'm getting older, maybe I should slow it down a little and soften the ride on my arthritic butt. We'll see if I can control myself.
    PS The tire profile on the diagram looks like pre-radial, maybe even pre-glass-belt.
  17. Remove Advertisements
