DIY Front Diff pic by pic fluid change for AWD
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By OMG
2008-2013 Cadillac CTS General Discussion Discussion, DIY Front Diff pic by pic fluid change for AWD in Cadillac CTS Second Generation Forum - 2008-2013; For those with AWD this is technically part 2 of my diff fluid change I did this while I waited ...
    OMG's Avatar
    OMG
    OMG is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 3.6DI
    Mar 2013
    Northern IL Suburbs
    30
    231
    For those with AWD this is technically part 2 of my diff fluid change I did this while I waited for the rear diff fluid to drain
    Now this is a lot harder because there's just a ton of more crap you have to deal with in a much tighter space.
    Things you'll need.
    Tools:
    10mm Hex socket
    Ratchet (this is where a flex head is ideal!!)
    Drain pan
    Pump
    Supplies:
    Towels
    Fluid
    1.5pints GL-5
    The hardest part about this is really just the fill plug is a little hard to access too. I found the easiest way was to feed the tool through the side of wheel well then your hand through another hole in the wheel well to position the 10mm socket into the plug. It's a little hard to explain so I will lt a bunch of pictures explain. Once you pop it out it has a little bit of drainage.
    After you get the plug off it's just the drain plug now!
    A quick video of the drain cause I thought it was cool.
    http://s1030.photobucket.com/user/om...88183.mp4.html
    Sadly I forgot to take a picture of pumping the fluid back in. But it's pretty straight forward.
    Hope this helps people if you were thinking of doing it! Hopefully next week I'll get the transfer case done.
    Merge likes this.
    Tbbt is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,340
    Re: DIY Front Diff pic by pic fluid change for AWD
    OMG,
    Great write up! Thanks for taking the time to do this! What fluid did you use?
    Marv
    OMG's Avatar
    OMG
    Mar 2013
    Northern IL Suburbs
    30
    231
    Quote Originally Posted by Tbbt View Post
    OMG,
    Marv
    OMG sorry I never got back to you on this, but I used Royal Purple Max Gear 75w90 which honestly now I think I'm starting to regret.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Why?
    OMG's Avatar
    OMG
    Mar 2013
    Northern IL Suburbs
    30
    231
    A whine has developed in my rear LSD diff. Which at first I thought was a wheel bearing. After replacing all 4 and realizing only one of them was bad you can really hear the whine. It was advertised to have the Limited Slip additive already added. Well I went to the GM dealership and purchased the limited slip additive and added it. It has reduced the noise after about 30 miles, but it's still there just not as loud. After searching on the forums a bit, it seems that when the noise comes it's not fixable unless the diff is replaced or a crazy procedure is done.
    Tires still have a lot of meat left in them so I don't want to drop $600 on replacing them based on a theory.
    Douglas Rome is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-4 3.0 sedan black/black
    Aug 2013
    Elburn IL
    71
    308
    OMG, you are a man after my own heart, good job!
    thanks, Douglas
    Z71's Avatar
    Z71
    Z71 is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    May 2005
    1,379
    The noise is a result of the meshing of the rign and pinion gears. They claim this is normal noise of the Getrag Axle that is being transfered into the passenger compartment. They will ONLY replace it if the customer complains vehemently. Of course thats only if you have warranty left...
    OMG's Avatar
    OMG
    Mar 2013
    Northern IL Suburbs
    30
    231
    Quote Originally Posted by Z71 View Post
    Yeah whine came up after the warranty expired in July. It's too cold for me to tackle this now and with classes in full bore I'll check it out myself come next may. Hot a couple of things in mind.
    karstman7 is offline Cadillac Owners Member
    Automobile(s): cts di
    Mar 2011
    53
    thanks for great pics and DIY - I'm going to tackle this over the weekend
    OMG's Avatar
    OMG
    Mar 2013
    Northern IL Suburbs
    30
    231
    Quote Originally Posted by karstman7 View Post
    Good luck! It's an easy job for sure!
    Also wanted to update everyone that the whine was indeed my tires awhile back (like a year ago). P-Nero's. Replaced with the Hankook Ventus. Cadillac quiet again.
    Backinblack11 is offline Cadillac Owners Fanatic
    Automobile(s): Traded in that boat anchor
    May 2015
    Orlando FL
    52
    106
    I currently have the P-Nero's also and I am not impressed with the road noise and thumping I am getting from these tires. I have always had great luck with Cooper tires so that's what I will be putting on mine when they are due
    KirkEllis's Avatar
    KirkEllis is offline Cadillac Owners Member
    Automobile(s): 2011 CTS4
    Aug 2014
    Chicago, IL
    57
    I have a 2011 CTS4 with 86k miles. I had the dealer drain/fill the trans around 50k. I plan on having the trans serviced again around 100k along with the differential and possibly the transfer case fluid. I read where the transfer case has an obstruction that makes a fluid change difficult? Tinman, I know this was discussed in a prior thread, I just can't find it.
    I have the GM fluid part numbers (trans- 89021677), with the 4oz (LS additive - 88900330). I see Mobil One has a product with the limited slip additive already mixed in (Mobil 1 104361 75W-90 Synthetic Gear Lube - 1 Quart)
    This thread is a few year old, but I noticed that OMG was concerned that he did not have enough LS additive when he used Royal Purple Max Gear 75w-90 with LS already added. Turns out, the noise was from his tires.
    Any good/bad experiences using a non GM all-in-one gear lube with the LS already mixed in?
    Also, any updates on servicing the Transfer Case would be helpful.
  15. Remove Advertisements
