DIY Rear diff (w/ LSD) pic by pic fluid change! PIC
Results 1 to 8 of 8
Like Tree5Likes
  • 1 Post By OMG
  • 3 Post By OMG
  • 1 Post By tinman
2008-2013 Cadillac CTS General Discussion Discussion, DIY Rear diff (w/ LSD) pic by pic fluid change! PIC in Cadillac CTS Second Generation Forum - 2008-2013; Honestly this is easier then changing the oil of the car! I can see doing this every 25-30k mi since ...
    OMG's Avatar
    OMG
    OMG is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 3.6DI
    Mar 2013
    Northern IL Suburbs
    30
    231
    Honestly this is easier then changing the oil of the car! I can see doing this every 25-30k mi since it's so hassle free. For the AWD folks here is also the front diff: http://www.cadillacforums.com/forums...l#post10551018
    Here's what you need:
    Tools:
    10mm Hex Socket
    Ratchet (Flexi-head makes it easy but not neccessary)
    Drain pan
    Fluid pump is ideal and makes it A LOT easier but you can use the long tube and gravity has always worked for me.
    Supplies:
    2.5 Pints of Diff fluid GL-5
    ~4OZ (3.38 to be exact) Limited slip aditive GM Part No. 1052358
    OR
    2.7 Pints of fluid with the additive already added (what I chose)
    First jack the car up. I use a combination of 3 jacks and 4 stands. I use two jacks in front of the car to adjust the the levelness of the car and keep two stands in place in cas they fail. But one of the jacks has a lock so even if it fail it would not fall. But you can never be too safe! Especially with our 4300lb land barges! I also jacked the driver side *just* a few degrees higher to get the fluid to drain to the drain hole as much as possible!
    Ok the pics.
    Here is to get some orientation. Don't open your drain plug just yet!!!
    Now find your fill plug. It is right under your passenger side axle. There is plenty of space to reach up with almost nothing in your way.
    Insert your 10mm hex socket
    Then your ratchet
    Clearview to show how much room you'll have
    Fill plug removed. It honestly took very little effort to get it out with almost no resistance after the intial break you can simply unscrew with our hand. There are definitly some shavings made me cringe to see it...
    But it gets worse...drain plug removed. Get your pan and towels ready because it will simply shoot out like a straight beam of black liquid! And the smell! It's almost like gasoline and engine oil!
    If you think the fill plug was bad check out the drain plug which is magnetized!
    The big shavings are wiped off
    What's left is *very* fine shavings that is almost putty like. (careful they will stain your hands and clothes and is a pain to get out!)
    After a few towel wipings it'll look like this!
    HalenG likes this.
    OMG's Avatar
    OMG
    Mar 2013
    Northern IL Suburbs
    30
    231
    Re: DIY Rear diff (w/ LSD) pic by pic fluid change! PIC
    Now for the tools and fluids in the ready. But at this point I let the diff drain in the mean time I went and prepared to drain the front diff.
    Ok! While the front diff is draining I went back put the drain plug in and position the hose over the exhaust piping to reduce the chance of the hose popping out while I am pumping.
    When you get to the bottom of the bottle I actually grabbed the bottom of the bottle and used the bottom of the suspension to push against the top of the pump like so!
    Keep pumping until you see it overflowing past the fill hole. In this scenario I actually lowered the driver side just a *few* degrees.
    Plug it back up and you're done!
    Any suggestions, feedback, or questions feel free to ask guys!
    kdstrum, Merge and HalenG like this.
    Tbbt is online now Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,435
    OMG,
    Again, another great job!
    Thanks, Marv
    karstman7 is offline Cadillac Owners Member
    Automobile(s): cts di
    Mar 2011
    53
    thanks - i feel like this is mainly what this forum lacks - MORE DIY threads....
    my other forum (RX8) overflows with diy threads - is this group too hoity toity to DIY?
    OMG's Avatar
    OMG
    Mar 2013
    Northern IL Suburbs
    30
    231
    Quote Originally Posted by karstman7 View Post
    I think it has to do with more of the fact that the majority of people who purchase this car have the means to pay for someone to do the services for them and are in for the luxury and convience of having a luxury car (which the whole point is being spoiled by the experience). Whereas a performance car like the RX8 or Corvette (where I originated from) yes there are TONS of DIY threads. Our cars at least the V6 are mostly grocery getters. Look at the V forums to really see the disparity. I can afford to pay the dealer to fix the major problems if I had too. But I cannot afford the astronomical maintenance AND repairs. Thus I do what I can myself. I am a minority (as I am sure you and a handful of people on the forum.) But we represent abvery small amount of buyers of this car and an even smaller amount of ones that buy it new. I also want Cadillac to develope a cult like following much like BMW where it even past models are still revered and preserved. Which I think this 2nd gen has achieved. But it starts only with a handful of people whom cms't quite afford the full brunt of owning such a car but by opening these doors we let others in.
    tinman's Avatar
    tinman is online now Cadillac Owners Master
    Jul 2006
    Jacksonville, Florida
    9,714
    Nice writeup.
    I was on a Forum where we had a "Knowledgebase" where folks would put in writeups such as the one you just did. It was an excellent part of our forum.
    I have taken the time to copy and paste writeups such as yours and place them in my own Knowledgebase so I have these things readily accessible for when I need them instead of having to take the time to hunt all over these digital ones and zeros.
    If anyone needs a copy I am happy to share it. Just PM me your real email address so I can send it to you. I can't send it via this Forum's PM system.
    OMG likes this.
    toothpaste is offline Cadillac Owners Fanatic
    May 2017
    117
    My front drain plug had more "sludge" while my rear drain plug had more shavings and looked almost identical to OP's:
    May 2017
    117
    When I opened the rear fill plug, there wasnt any "excess" fluid unlike the front.
    When I opened the front fill plug, quite a bit of fluid came pouring out.
    After filling the rear, I waited until the excess fluid essentially came to a slow drip before replacing the plug.
    I left a little more fluid in the front diff since there was so much to begin with. I replaced the plug once the fluid came to a medium paced drip.
  11. Remove Advertisements
