2008 CTS HID headlight parking light strip is dead
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By t5mika
2008-2013 Cadillac CTS General Discussion Discussion, 2008 CTS HID headlight parking light strip is dead in Cadillac CTS Second Generation Forum - 2008-2013; I had the passenger side DRL go out intermittently. I pulled the headlights out and cleaned the contacts inside the ...
    t5mika is offline Cadillac Owners Member
    Automobile(s): CTS
    Dec 2011
    51
    I had the passenger side DRL go out intermittently. I pulled the headlights out and cleaned the contacts inside the housing and it started working again.
    At the same time I noticed that the driver side parking light strip, the clear one on the outside edge, is dead. There does not seem to be any way to change the bulb (LED?) on either the clear or the amber parking light, is there? I opened all the access panels on the housing but there's no room to get to those bulbs without splitting the housing or dremeling a new access hole. The problem does not seem to be in any harness contacts, relays or fuses, I checked them all.
    The car is 2008 CTS DI with HID headlights.
    Automobile(s): CTS
    Dec 2011
    51
    Re: 2008 CTS HID headlight parking light strip is dead
    Anyone? Bueller?
    Tbbt is online now Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,351
    As you might have guessed, there haven't been many headlight issues with the parking lights. Keep your eye open on eBay for a replacement or maybe one of the members here might have one for sale. Otherwise give one of the dealers on here give you a quote for a new one.
    Automobile(s): CTS
    Dec 2011
    51
    I gathered as much. Maybe I will need to give my Dremel a chance...
    KPE's Avatar
    KPE
    KPE is offline Cadillac Owners Enthusiast
    Automobile(s): 12 CTS-V Wagon, 10 CTS Wagon S/C, 13 ATS 2.0, Escalade Plat
    Apr 2010
    Scottsdale, AZ
    46
    764
    Let me know how that works out. I would like to make the outter LED parking lamps brighter. I was thinking of adding a higher wattage LED to the back of the housing.
    [FONT=Century Gothic] KPE Products
    Sales@KPE-Products.com
    www.KPE-Products.com
    Automobile(s): CTS
    Dec 2011
    51
    I found pics here on the site of a guy splitting his headlight open. I think he used oven at 200 degrees for 15 minutes for softening the adhesive between the lense and the housing. I found heat gun worked better for me. Sorry I did not save the thread to link here, but I'm sure Google knows where it is.
    So I bought a headlight unit on eBay for spares. It had broken tabs and the lense was not as good as mine so I couldn't use it as such.
    Taped the lense to protect
    Used heat gun and a large screwdriver to split the housing open (after removing torx screws from behind).
    This is not super difficult, but it's easy to damage the lense. The trick is to pry only on the inside and bottom edges which are not visible, get fingers in between and pull apart.
    Here's the LED for the light strip. It could be accessed by Dremeling the lower corner of the housing open.
    The electronics for the LED. It appears my problem was a blown LED, the electronics was fine.
    Another angle
    The actual LED under the cap
    For assembly, I removed all of the old adhesive with a heat gun and a knife. This took the longest.
    I used marine silicone for caulking instead of urethane or epoxy since I wanted to make sure I can open it again. And of course I had to open it since I forgot to connect one wire...
    And it works again
    If anyone needs any parts from my spare, PM me. It all works. I got all the electronics, lenses, reflectors, and the HID bulbs. The blinker and DRL bulb is gone.
    Merge likes this.
    roquevc is offline Cadillac Owners Member
    Automobile(s): cts
    May 2012
    28
    18
    Quote Originally Posted by t5mika View Post
    Another angle
    And it works again
    lets say I have the same problem a blown LED, but I don't have a spare light, where can I find an led bulb for the strip>?? helppppp please
    Ebt217 is offline Cadillac Owners Member
    Automobile(s): 2008 cts di awd
    May 2014
    7
    I am looking for the fuse to this led side light. Please tell me what fuse it is
    Panzer Leader's Avatar
    Panzer Leader is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS 3.6 V6 RWD Performance Sedan
    Jun 2012
    Mandeville, Louisiana
    588
    Please don't tell me that if the LED strips go bad, then the whole headlight assembly must be replaced.
    randsom is offline Cadillac Owners Member
    Dec 2014
    3
    Does anybody have the LED part number for that strip light change?
    rtlawlor is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac CTS 3.6L Direct Injection
    Jun 2014
    Huntington Beach, CA
    31
    22
    Is it possible to put a bigger LED in for the strip? Is it just one LED on the top that illuminates the strip? Or is there one at the top & bottom? I want mine to be a lot brighter! And I want them to illuminate as my (DRL)
    Any thoughts? Advise? Tips??
    Automobile(s): CTS
    Dec 2011
    51
    There's only one LED, and it's already quite bright. The design of the light tube just doesn't allow it to actually illuminate anything as it just diffracts the light.
    You could always add your own LED on the top of the strip with your own wiring (e.g. from the DRL bulb). Or you could replace the whole thing with a real LED strip.
    FRANCISCOXG is offline Cadillac Owners Member
    Automobile(s): 2008 CTS
    Jun 2015
    1
    Hello everyone. I have been looking for this exact type headlight for some time now and haven't had any luck with finding them On my own. Any of you Have a link of a site where I can find these exact headlight with the led light strip on the side? Or any sticker information on them? thanks!
  16. Remove Advertisements
