jacking advise for 2011 cts
Results 1 to 7 of 7
2008-2013 Cadillac CTS General Discussion Discussion, jacking advise for 2011 cts in Cadillac CTS Second Generation Forum - 2008-2013; so I was advised not to slide the floor jack under the front center of the car to raise the ...
    benigs is offline Cadillac Owners Member
    Automobile(s): 2011 cts///1967 chevelle ss 396--4 speed(kinda like a caddy!
    May 2013
    Hobe Sound, Fl
    10
    so I was advised not to slide the floor jack under the front center of the car to raise the front. The reason was that the cts does not have a cross member like the older vehicles, such as my 67 chevelle. The only place the jack should be used is the 4 points specified, behind each front tire and in front of each rear tire. What if I wanted to raise the complete front? Also I thought if I wanted to raise the complete rear end, I could place the jack under the "pumpkin" in the middle of the rear housing? Thanks for any advise as I sure as hell don't want to do any damage!
    CTS4MATION is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS4
    Jun 2012
    PA
    155
    Re: jacking advise for 2011 cts
    Im in the same boat man. Ive had the wheels off a few times in the past couple weeks and its a PITA pulling them off 1 by 1. I havent found any other way to do it. But im also in the same boat as you..... there may be a way to do it but im not willing to risk my jack going through something of breaking something. So I just go for the sure thing and pull them 1 at a time.
    MD-11's Avatar
    MD-11 is offline Cadillac Owners Member
    Automobile(s): 12 CTS Coupe, 12 CTS-V Sedan
    Mar 2011
    91
    jimmie jam's Avatar
    jimmie jam is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS LUXE
    Oct 2007
    FORT LAUDERDALE
    347
    Thank you MD for the Rx.
    May 2013
    Hobe Sound, Fl
    10
    Yes MD---thanks!!
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,714
    FYI, I use a hockey puck on my hydraulic jack to avoid any damage to the car. I also use ramps, too, along with wheel chocks - just in case. Please, please be sure NOT to get under your car with only a jack holding it up. Use either ramps or jack stands!!!!!!
    99flhr is offline Cadillac Owners Enthusiast
    Automobile(s): CTS
    Jul 2012
    N.E. OH
    722
    Having two jacks simplifies the process.
  10. Remove Advertisements
