Results 1 to 13 of 13
Thread: Battery drain
    John Young is offline Cadillac Owners Member
    Automobile(s): 2009 CTS
    Jun 2013
    3
    Battery drain
    I have a 2009 CTS that has had an ongoing battery drain. The dealer could not
    locate. Battery was dead this morning and noticed a faint clicking noise on both the driver and passenger doors. Sounded almost like a fan clicking. Pulled the door
    lock fuse and the sound on the drivers door ceased. Pulled the passenger door
    module fuse and the sound on the passenger door ceased. Thought it might be the door lock relay sticking but could not locate relay block in trunk.
    On a side note, my wife
    told me she reset the seat position and pressed the memory button. The chime
    sounded but the new position was not retained. She also said that when
    approaching the car yesterday after shopping, the car was running and the doors unlocked. She does have a habit of carrying multiple key fobs and leaving one in the car which results in the 3 horn beeps after exiting. Not sure if that could be causing the problems. We just had the car in the shop last week. Everything has been
    working well until this morning. PS - she did leave the key fob in the car yesterday but the car started fine afterwards.
    Tbbt is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,403
    Re: Battery drain
    John,
    Welcome! There have been instances of this problem, caused by the seat module. Do a search for more information, I don't remember the details, but it's happened before.
    I just found this info,
    "Here is a TSB for a similar problem on '08s and '09s.
    TECHNICAL
    Bulletin No.: 09-08-50-002A
    Date: September 09, 2009
    Subject: Vehicle Will Not Crank/Start, Battery Goes Dead, Four Amp Draw From Memory Seat Module (MSM) (Reprogram MSM)
    Models:
    2008-2009 Cadillac CTS, CTS-V
    Built Prior to VIN Breakpoint 90160070
    Equipped With EZ-Key RPO UHA, UHF
    Supercede:
    This bulletin is being revised to provide a VIN breakpoint. Please discard Corporate Bulletin Number 09-08-50-002 (Section 08 - Body and Accessories).
    Condition
    Some customers may comment that the vehicle will not crank or start and the battery goes dead.
    If battery electrical drain/parasitic load testing is performed while the condition is present, a four amp draw can be traced to the memory seat module (MSM). The draw will be present until the battery goes dead, the MSM power is disconnected, or the 1 or 2 memory switch on the driver door is pressed.
    Cause
    This condition may be caused by a software conflict within the MSM that causes the low speed GMLAN bus to stay awake if the vehicle detects keyless transmitter number 3 or number 4 and the memory seat recall/easy exit recall is set to ON in the driver information center (DIC).
    Note
    This condition will only happen if all three of the conditions listed below are true.
    - The vehicle has the EZ-key option (RPO UHA, UHF).
    - The memory seat/easy exit recall is set to "On" or "Automatic On".
    - A fob driver ID of greater than number 2 is used.
    Correction
    - A revised calibration has been developed to address this condition.
    - Reprogram the MSM using the Service Programming System (SPS) with the latest calibration available on TIS2WEB. Refer to the SPS procedures in SI.
    - During programming, the battery voltage must be maintained within the proper range of 12-15 volts. Only use the approved Midtronics(R) PSC550 Battery Maintainer (SPS Programming Support Tool EL-49642) or equivalent during programming.
    - When using a Tech 2(R) for reprogramming, ensure that it is updated with the latest software version.
    - When using a multiple diagnostic interface (MDI) for reprogramming, ensure that it is updated with the latest software version."
    Good Luck, Marv
    Jun 2013
    3
    Re: Battery drain
    Thanks Marv,
    This may be the problem. I will contact the dealership with the information.
  5. #4
    hauler's Avatar
    hauler is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 Sportwagon 18.2city 28hwy 25hwy AC on
    Nov 2012
    Moline,IL
    531
    Re: Battery drain
    I would like to meet the genius who was able to figure out that the conditions named in the service bulletin would cause a dead battery. Diagnosing electrical bugs in cars is getting waaay complicated.
  6. #5
    Jun 2013
    3
    Re: Battery drain
    New development. Just jumped battery and started car. Odometer reads 999,999. Any suggestions?
    I tried to reprogram my key fobs to no avail. The car thinks all of my fobs(I have 3), are #4.
  7. #6
    Aug 2012
    Castle Pines, CO
    73
    2,403
    Re: Battery drain
    Wow! Bizarre. Please let us know what the dealer figures out here! Ugh!!!!!!!!!!
  8. #7
    snafu's Avatar
    snafu is offline Cadillac Owners Fanatic
    Automobile(s): 08 CTS DI AWD Luxury-Performance II ThunderGray/Titanium
    May 2010
    Cincinnati
    128
    Re: Battery drain
    [QUOTE=John Young;3584202]New development. Just jumped battery and started car. Odometer reads 999,999. Any suggestions?[COLOR="Silver"]
    You might be spending tooooo much time in your car...
    Did it spark when you hooked up cables?
  9. #8
    Mar 2010
    Detroit, USA
    12,711
    Re: Battery drain
    Hello John,
    I am sorry to hear about this frustration you are experiencing with your vehicle! You mentioned that the dealer could not locate what was causing the battery to drain. Was this a recent trip to the dealership? If you could provide more information through a private message, we would be happy to assist further in a resolution for you. Please provide your phone number, VIN, vehicle mileage, and name of involved dealer and we can look into this further for you. Thank you!
    Jessica
    Cadillac Customer Care
    Quote Originally Posted by John Young View Post
  10. #9
    hauler's Avatar
    Nov 2012
    Moline,IL
    531
    Re: Battery drain
    Drive one mile and restart your warranty from zero..... A poor attempt at humor from a guy who hopes it never happens to his car.
  11. #10
    jeffc83's Avatar
    jeffc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS4 DI Premium (SOLD) / 2013 XTS Luxury (TOTALLED) / 2015 BMW 328i XDrive Lux
    Feb 2012
    Southeastern PA
    1,957
    Quote Originally Posted by hauler
    That's absolutely correct...it took my dealership days to figure out the CEL was being triggered by a short in the wiring from/to the ECM. They did a great job but they did say that I wouldn't want to see that bill let alone pay for it!
  12. #11
    Mar 2010
    Detroit, USA
    12,711
    Re: Battery drain
    Quote Originally Posted by jeffc83 View Post
    Hello jeffc83,
    I am glad the dealer was able to figure out your vehicle issue. Happy to hear about a satisfying trip to the dealership. Don't hesitate to contact us in the near future with any other concerns or questions.
    Laura M.
    Cadillac Customer Service
  13. #12
    ultimate_ed's Avatar
    ultimate_ed is offline Cadillac Owners Fanatic
    Jul 2007
    Texas
    188
    Re: Battery drain
    I have begun having this same issue with my battery getting drained. I'm taking it to the dealer tomorrow to see if they can figure it out. I'm bringing the text of the TSB as well. I've been searching the forum for battery issues to see if I can find a clue for what they should look for.
    One thing that jumps out at me is the using a key fob greater than #2. This summer, my number 1 fob broke and I bought a replacement. However, the car would only let me program it as FOB 3 and that is what I use now. I suspect I starting having my battery drain issues after programming and using that new FOB.
    The first couple of times I found my battery drained, there was a clicking noise coming from the passenger seat. After the second time, I just unplugged the wiring harness to the passenger seat. But a week later, I had my battery drained again.
    I'll report back and let you know if this TSB fixes my issue.
  14. #13
    agreif is offline Cadillac Owners Fanatic
    Jun 2009
    100
    Re: Battery drain
    able to resolve this one?
  • You may not post replies
