Need help with DTC error code C0040 ABS AWD
Results 1 to 2 of 2
2008-2013 Cadillac CTS General Discussion Discussion, Need help with DTC error code C0040 ABS AWD in Cadillac CTS Second Generation Forum - 2008-2013; This is on a 2008. Text warning on in IP are Traction off, All Wheel Drive off, Service Brake Assist, ...
    ebby69k is offline Cadillac Owners Member
    Automobile(s): 2008 CTS
    Oct 2012
    55
    11
    This is on a 2008. Text warning on in IP are Traction off, All Wheel Drive off, Service Brake Assist, Service Stabilitrac. Lights on are ABS, Trac off. I picked up a Innova 3160b Scanner. It reads
    C0040 code with this listed under it
    1. Right Front Whell Sensor circuit eratic
    2.Right front wheel sensor malfuntion
    3.Right front wheel speed circuit signal amplitude < minimum
    4.Right front wheel speed sensor circuit
    I ordered a new a/c delco wheel sensor from Rock Auto. I cleared the code and it all came back.
    The part number they gave me was 22897414. The original was 25878148. Could this be the problem?
    What should I attempt to check next.
    After clearing the code and the first time pressing the brakes I can feel the anti lock kicking in.
    texasredbud is offline Cadillac Owners Member
    Nov 2011
    37
    6
    Re: Need help with DTC error code C0040 ABS AWD
    I have been told that this error code is most often due the magnetic ring that the sensor reads. The problem is, the ring is on the
    wheel bearing and has to be replaced.
