Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: TRANSMISSION POWER FLUSH @ 50K miles
    danoh123's Avatar
    danoh123 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS 3.6 Premium AWD
    Sep 2012
    Boston area
    167
    All the cars I had I never power flushed my transmission until after 100,000 miles. I see that we are recommended by Cadillac (v6 3.6L) to do so at 50,000 miles. It costs about $250. Do you thinking this is worth the money?
    Tbbt is online now Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,401
    Re: TRANSMISSION POWER FLUSH @ 50K miles
    Danoh123,
    I don't have my manual handy, but is the dealer saying it should be done or the owners manual? I will check my manual.
    Just off the cuff, it would be odd for a modern transmission to need a power flush at 50K. Even if the manual tells us to do it, I wouldn't. A power flush doesn't remove the old fluid from the torque convertor and that's a no no. I'm guessing your dealer is trying to up-sell this? Let us know, Marv
    BreakingThrough's Avatar
    BreakingThrough is offline Cadillac Owners Fanatic
    Automobile(s): Thunder Gray '08 CTS 3.6 FE2 Premium
    Apr 2011
    Hermosa Beach, CA
    33
    325
    I've been wondering the same thing. I just hit 50k on my '08, and the manual recommends "Change automatic transmission fluid and filter (severe service)" at 50k. It doesn't specify "Power Flush" vs. "Drain and Fill."
    I *think* I might qualify for "severe service" (mostly city mile trips of less than 10 miles, only occasional freeway driving), but I'm not sure if they mean SEVERE, as in livery service severe. Can't trust the dealer -- they just want to upsell. As much as I like my dealer, I saw them turn some poor old man's $30 oil change into a $900 service on his Buick in the waiting room.
    What would you do?
  5. #4
    exm22psu is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS DI AWD Premium
    Apr 2009
    46205
    45
    585
    I changed mine myself at 55,000 miles. The hardest part is refilling the pan. I used a cheap pump and mounting tape to secure the hose in the drain plug (to take up the gap and limit the chance of fluid spilling back out rather than entering the pan). Once I had pumped the quarts into the pan, with the car level, I removed the pump hose and let it drain even and installed the bolt.
  6. #5
    tinman's Avatar
    tinman is online now Cadillac Owners Master
    Jul 2006
    Jacksonville, Florida
    9,549
    Is this something you can do yourself?
    Never "Power Flush" anything except a toilet, and then be careful.
    If you can do it yourself, I can send you (not PM you, but via your real email) a How To on this very topic. I was getting set to do this, but since I have 50,000 miles and my transmission dropped out twice in the past 30 days I do believe it has been done for me.
    I would have rather done it myself, thankyouverymuchCadillac.
  7. #6
    danoh123's Avatar
    Sep 2012
    Boston area
    167
    Power flush costs $260. I believe the charge is from using special pressure generating equipment with detergent to clean out the transmission. BTW - i had a problem with transmission of 2004 Toyota Sienna at around 130,000 miles. The low gear had some jerking motion. 2 Power flush did not help at all. My friend recommended I use $10 Lucas additive: It solved the problem.
  8. #7
    Z71's Avatar
    Z71 is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    May 2005
    1,379
    FORGET THE IDEA OF FLUSHING YOUR TRANSMISSIONS. Normal transmission maintenance is a good idea. Drop the bottom pan, change the filter and clean everything up and refill the transmission with fresh fluid. Do the cooler line/bucket purge if you arereally fastidious about changing all the fluid... but... DO NOT hook your transmission up to a flush machine. A flush will do absolutely nothing more than a good drain and refill will accomplish... and potentially a lot of harm. Do not take the risk. Just because some have had good experiences (or the lack of a bad experience) with a flush does NOT mean that they will always go good.
    There has never been a reason to power flush a transmission other than to sell more transmission fluid. Thats what the machines were invented to do, make it easy for amateurs to sell ATF.
  9. #8
    MoFex's Avatar
    MoFex is offline Cadillac Owners Connoisseur
    Automobile(s): 08 White Diamond CTS DI RWD FE2 all options
    Oct 2007
    metro Atlanta
    61
    2,541
    Quote Originally Posted by Z71
    Absolutely agree!
  10. #9
    Joe is offline Cadillac Owners Fanatic
    Automobile(s): 08 CTS blk/blk
    Jul 2010
    MA
    68
    383
    Don't waste your money. The fluid should be normal unless the transmission is giving you problems. GM will be happy to flush the cash out of yourwallet. I love GM but some of these money grabs are insulting.
  11. #10
    danoh123's Avatar
    Sep 2012
    Boston area
    167
    Dealer claims that without power flush only 80% of transmission / transfer case fluid can be drained thus they do not provide a service to simply drain and replenish the fluid. Well, I did not change the fluid at 50k.
  12. #11
    MaxBuck is offline Cadillac Owners Member
    Automobile(s): 2009 CTS4 DI Blue Diamond
    May 2013
    64
    64
    Seriously, what is the reason for changing one's transmission fluid?
  13. #12
    tinman's Avatar
    Jul 2006
    9,549
    Because after 50,000 miles or 5 years it has to deteriorate. Dirt and shavings get suspended and will slowly wear your parts, too. Change out your fluids, all of them. This includes Differential fluids, too. Why change your motor oil?
    I'm not recommending changing out your trans and diff fluids every 10,000 miles, but they do need to be attended to.
  14. #13
    May 2013
    64
    64
    Just re-read the owner's manual. Recommends changing (not flushing) the ATF at 100k intervals. Sounds reasonable to me.
  15. #14
    tinman's Avatar
    Jul 2006
    9,549
    Whatever works is fine.
    They also recommend changing the oil every 10,000 miles or so or whenever the diagnostics tell you. It might even recommend changing the oil once a year. To each his own. I'm good with 100k on the trans, but I would have changed mine at 50k if I hadn't dropped my transmission (twice) at that mileage.
  16. #15
    HurstGN is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,769
    Note, all fluids, that also means brake fluid should be changed. Many people omit this one.
  • You may not post replies
