Moon roof leaks
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 30
2008-2013 Cadillac CTS General Discussion Discussion, Moon roof leaks in Cadillac CTS Second Generation Forum - 2008-2013; i have a 2008 cadillac cts 3.6 di and my moonroof is leaking. i heard that it is a defect ...
    touchdown1999 is offline Cadillac Owners Member
    Automobile(s): 2014 ats 2.0T
    Jun 2013
    43
    5
    Moon roof leaks
    i have a 2008 cadillac cts 3.6 di and my moonroof is leaking. i heard that it is a defect in the cts model. how do i resolve my issue? thanks, mike
    Tbbt is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,264
    Re: Moon roof leaks
    There are MANY threads on this topic. Please don't start a new one. Search can be your friend if you use it.
    billeee is offline Cadillac Owners Fanatic
    Automobile(s): 2011 DTS 2012 CTS
    Jun 2011
    114
    Re: Moon roof leaks
    Old Chinese proverb:
    Never put window in roof.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,687
    Re: Moon roof leaks
    Quote Originally Posted by touchdown1999 View Post
    Hello Mike,
    If you private message me with your VIN and current mileage, I am more than happy to further assist you with this concern.
    Regards,
    Laura M.
    hauler's Avatar
    hauler is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 Sportwagon 18.2city 28hwy 25hwy AC on
    Nov 2012
    Moline,IL
    531
    Re: Moon roof leaks
    Lots of good information and advice here: http://www.cadillacforums.com/forums...-me-about.html
    Jun 2013
    43
    5
    Re: Moon roof leaks
    hi Laura m. I (PM'd you). I also noticed that the water leaked into the trunk of my 2008 cts. it is damp in the trunk area where I had the water build up in the rear floor and seat. I also noticed the leak in front also. the water build up varies on how the car is parked. it depends on the tilt of the parked vehicle on the street. I have read some of the forums and it has been stated that General Motors is aware of it and they have been addressing the issue on most occasions. I do have a warranty. please help me resolve this issue. thanks, Mike.
    thanks hauler for the link. it was helpful
    Mar 2010
    Detroit, USA
    12,687
    Re: Moon roof leaks
    Hello Mike,
    I see that Laura has responded to your PM and asked you for some additional information. She will be out of the office for the weekend, but I will be sure to pass along the information to her when she gets back on Monday. Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
    jlmhester is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac CTS Sedan
    Mar 2014
    38
    6
    Re: Moon roof leaks
    I am having the same type issue with my 2008 CTS. About a month ago I opened the trunk of my car and noticed mildew on a leather jacket that had been stored in it. This prompted me to investigate further. As I removed the contents of my trunk I discovered that the entire floor of my trunk was wet and mildewed. I removed the panel that covers up the spare tire. That entire space under the panel was full of water. It appeared the water was evaporating upward into the trunk causing the trunk floor to be wet and mildewed. I used a shop-vac to remove the water and cleaned my trunk the best I could, thinking it was just a minor mishap. I didn't put anything else back in my trunk. Two weeks later, I opened the trunk and discovered that space was full of water again. I then took it Chevy Dealer I bought it from. The service associate was completely puzzled to why this would be happening. He sent me to a local body shop that they use because they don't do body work the at dealership. The owner of the body shopped looked at my problem and thought that it would be a simple fix, some minor leak around the tail light or something like that. Once he got to my car and tried to fix it, he discovered that it was coming from the moon roof. The actual roof its self was not leaking but the drainage system was not working properly. I was told that the drainage system on my car was a bad/faulty design. They are parts that are not long enough to adequately run the water off, the tubing is the same length that is used with sun roofs( my car has both sun and moon=doubling the size and space) and the flaps at the end of the tubes where the water comes out, don't always open. He also said that it had been leaking for a long time and was by far the worst leak he has every seen. There is significant amount of water damage to my car. He found large amounts of mold or calcium like deposits under the head liner, the rear floor, and in my trunk. Of course my car is no longer under warranty and the dealerships says there is nothing that they can do. I am beyond disgusted with this issue. I understand that issues arise with normal wear and tear on a vehicle, but this is not normal. I can count on one hand how many times the moon roof has been opened. What I don't understand is the fact that the drainage system has failed due to it's inadequate design and no one wants to accept responsibility for it. I am still paying on this car. I bought a Cadillac and I expected Cadillac service. This has not been the case in my situation. I just want someone to make this right or help me with the steps to take to get this taking care of.
    snofun3 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Jaguar XF
    Oct 2009
    Kansas
    61
    362
    Re: Moon roof leaks
    Quote Originally Posted by jlmhester View Post
    Gheesh, what's not to love about a monoparagraph?
    Anyway, check post #2. Dozens of threads about this, just a short search and you'll know everything you could possibly want.
    Mar 2014
    38
    6
    Quote Originally Posted by snofun3 View Post
    Sorry if my monoparagraph offended you and thanks for the search tip. I did search the forum for threads and yes there is a lot of useful information but not a solution. I have been well educated on the design, function, and proper servicing of my sun/moon roof. This education is a little too late for me. The issue now is the cost of repairing the damage caused by inadequate drainage system. I posted in hopes of finding a recall or some assistance by Cadillac customer service.
    Oct 2009
    Kansas
    61
    362
    Re: Moon roof leaks
    Cadillac customer service chimes in on most threads, (including this one). Why not send a PM?
    Mar 2014
    38
    6
    Wow.....are you the forum police or what?? Give a break would ya? I did PM them, Thx for all your help and concern :-)
    Aug 2012
    Castle Pines, CO
    73
    2,264
    Re: Moon roof leaks
    jlmhester,
    Snowfun3 is a negative troll, pay no attention to him.
    Now for you, Glad you joined the forum yesterday. But like many new members, you came here too late. Maybe if you had been here before now, you would have already known you need to clean your drain lines and not had the damage. This is a great forum, absolutely full of information.
    Cadillac Customer Service I a member just like you and me. They do monitor the forum and provide assistance when possible, but you could get the same assistance by calling them.
    Again Welcome!
  16. #14
    Mar 2014
    38
    6
    Quote Originally Posted by Tbbt View Post
    jlmhester,
    Again Welcome!
    Thanks so much for your encouraging words. After reading some of the threads, I've bout figured that I am going to have to pay for this expensive lesson. Up until now I have really enjoyed my car with the exception of locking my self out from time to time, thank goodness for On star. I won't say that I will never own another Cadillac but I will say that I won't have another vehicle with a sun roof. Especially when it serves no purpose for me.
    I have been looking around at other vehicles but it's hard to get one with all the bells and whistles without a sun roof. A sun roof seems to be the standard of a luxury package.
    Thanks again for welcoming me and I truly appreciate all the knowledge I have gained from this forum.
  17. #15
    jeffc83's Avatar
    jeffc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS4 DI Premium (SOLD) / 2013 XTS Luxury (TOTALLED) / 2015 BMW 328i XDrive Lux
    Feb 2012
    Southeastern PA
    1,956
    ^^Welcome to the forum! You're absolutely correct... it's hard to find fully loaded Cadillac without a sunroof let alone other brands. It sucks when you're a person that doesn't really want one too. Good luck with your repair!
  18. Remove Advertisements
