120x5...What am I Measuring?
Results 1 to 4 of 4
2008-2013 Cadillac CTS General Discussion Discussion, 120x5...What am I Measuring? in Cadillac CTS Second Generation Forum - 2008-2013; What is and how do I measure the 120 mm dimension on our wheels? Is it between studs? Is it ...
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,269
    What is and how do I measure the 120 mm dimension on our wheels? Is it between studs? Is it across studs? Is it the diameter of the "circle"? What is it please?
    Black'10CTS4 is offline Cadillac Owners Fanatic
    Automobile(s): '10 CTS4 Prem 3.6DI, '08 CTS4 Prem 3.6DI, '00 STS
    Sep 2012
    37
    104
    Re: 120x5...What am I Measuring?
    Its the measurement of the circle created by the centerline of the studs. 5 lug isnt as easy others.
    Here is a link from tirerack that explains it:
    http://www.tirerack.com/wheels/tech/....jsp?techid=92
    It should be from the centerline of the stud to the circle directly across from it but you can get close to the same reading by measuring from the centerline of the stud to the back of one of the studs across from it.
    tinman's Avatar
    Jul 2006
    9,269
    Black'10CTS4, you are the MAN! Exactly what I was needing. Thank you.
    Sep 2012
    37
    104
    Glad I could help!
  7. Remove Advertisements
