How to Enter a CTS With a Dead Battery ? :(
Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Like Tree1Likes
2008-2013 Cadillac CTS General Discussion Discussion, How to Enter a CTS With a Dead Battery ? :( in Cadillac CTS Second Generation Forum - 2008-2013; The Battery is dead , I tried to open the driver door bu using hidden into the remote but doesn't ...
    Saeid is offline Cadillac Owners Member
    Automobile(s): 2010 CTS
    Jun 2013
    1
    The Battery is dead , I tried to open the driver door bu using hidden into the remote but doesn't work.So please tell me what I havta to do with my 2010 CTS ..... By the way, i found that I can use jump power points under the hood or the passenger door but I couldn't find them.... please help me I'm in trouble.
    Thanks in advance,
    The_Judge's Avatar
    The_Judge is offline Cadillac Owners Connoisseur
    Automobile(s): '11 CTS 3.6 Premium, Black on Black, 19" Summer Tire Package
    Jun 2008
    Hermosa Beach, California
    1,529
    Re: How to Enter a CTS With a Dead Battery ? :(
    Which battery is dead -- the car's battery or the battery in your keyless access device?
    reciprocity is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V (red), 2009 CTS Premium Sedan (red), 2016 ELR (Radiant Silver Metallic)
    Jan 2005
    California
    343
    You might post more info. about what's wrong, if you have keyless entry or not, and what you're trying to accomplish.
    Have you tried using the emergency key to open the driver's door? Do you have folding seats to access the battery in the trunk or the emergency trunk release?
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,722
    Quote Originally Posted by Saeid View Post
    Thanks in advance,
    Hello Saeid,
    I am sorry you are having an issue getting into your CTS because of the battery. Could you private message me some more info about your concern so I am able to do some more research on your behalf? Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
    99flhr is offline Cadillac Owners Enthusiast
    Automobile(s): CTS
    Jul 2012
    N.E. OH
    722
    The Battery is dead , i found that I can use jump power points under the hood or the passenger door but I couldn't find them.... please help me I'm in trouble.
    Thanks in advance,
    The remote terminals under the hood are located on the passenger side fender well, but since you have to open the door to open the hood< I don
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    The key is a good idea... It's inside the fob.
    The_Judge's Avatar
    Jun 2008
    1,529
    Quote Originally Posted by 1BadCadSTS View Post
    And the key inside the keyless remote works mechanically, not electrically, to unlock the driver's door, so it shouldn't matter that either the car battery or remote is dead.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    i think the OP said that they key didn't work ...
    The_Judge's Avatar
    Jun 2008
    1,529
    Yeah, but we don't know what he means by "key" -- the FOB or the metal key in it? Also, I've found that the metal key can be a bit hard to turn, which might lead some to conclude that it doesn't work.
    Jschmank's Avatar
    Jschmank is offline Cadillac Owners Fanatic
    Automobile(s): 08 Silver CTS AWD
    Dec 2005
    Topeka, Kansas
    246
    I ended up with a run down battery after loading a new navigation disk. I used the key to unlock the door, but I use the key to start my car vs the keyless remote. The key in the keyless fob should work. The jumper cable connections are on the passenger side but you have to remove the black plastic engine cover on the fender side to get to the negative connection point. The positive one is under a red plastic cover. It took my car some time to get enough juice to start. Also have check engine light on now after jumping the car.
    Z71's Avatar
    Z71
    Z71 is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    May 2005
    1,379
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,779
    You are probably getting the check engine light because you need to reset the throttle position sensor. Check your owners manual under dead battery.
    Merge's Avatar
    Merge is offline Cadillac Owners Fanatic
    Automobile(s): SOLD
    Apr 2011
    Canada
    228
    bphillips likes this.
  16. #14
    The_Judge's Avatar
    Jun 2008
    1,529
    Quote Originally Posted by Jschmank View Post
    I ended up with a run down battery after loading a new navigation disk. I used the key to unlock the door, but I use the key to start my car vs the keyless remote. The key in the keyless fob should work....
    If the battery in the keyless FOB is dead, the car won't recognize the FOB and it won't work. However, the metal key inside the FOB can still be used to open the driver's side door, to lock or unlock the glove compartment, and to unlock the optional pass-through door to the trunk, but it cannot be used to start the car -- there ain't no keyhole for that!
  17. #15
    Mar 2010
    Detroit, USA
    12,722
    Hello Jschmank,
    I apologize for any inconveniences your vehicle is experiencing after loading the new navigation disc. I see other forum members have offered advice on your situation. If you would like to further discuss your concerns, please reach out to me via private message and include your VIN.
    Sincerely,
    Laura M.
  18. Remove Advertisements
