Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: Heavy Duty Ceramic Brake Pads?
    vegaspanton's Avatar
    vegaspanton is offline Cadillac Owners Member
    Automobile(s): 2012 CTS coupe
    Dec 2012
    Las Vegas NV
    12
    I have had my 2012 3.6 coupe (performance package) for several months now. Absolutely love the car. However, the front wheels get very dirty in a short period of time from the heavy duty factory brake pads. I had a similar problem with my C6 with Z51 option and solved it with some quality ceramic brake pads. The CTS coupe is a daily driver. I can not find anyone that makes ceramic pads for the heavy duty brakes on the 3.6 CTS. (Auto Zone, Pep Boys, O Reilly's, Tire Rack, etc.) They all sell a semi metallic pad only for the heavy duty brake option. However, the ceramic brake pads are available for the standard brake package from several of the various manufacturers. Since it appears that no one makes ceramic brakes for the heavy duty brakes, is there a semi metallic pad that does not dust as bad as the factory pads?
    Bandit1's Avatar
    Bandit1 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 ATS 3.6 RWD Premium
    Oct 2008
    Ashburn, VA
    497
    Re: Heavy Duty Ceramic Brake Pads?
    Have you checked with Carbotech?
    Sep 2007
    Wilmington, NC
    13,969
    ACDelco makes ceramic pads too (usually)
    being a perf. pkg. maybe not but it's worth checking
    http://parts-catalog.acdelco.com
    use your VIN instead of picking the car for best results and ease of use
  5. #4
    arw1510 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
    Oct 2008
    1,229
    My 2004 cts brake dust is 100 times worse than my 2012 cts brake dust with the heavy duty brakes. Actually the best out of all my cars. Anyone else having the same issue?
  6. #5
    zen is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS CPE
    Apr 2010
    199
    most of the ceramic pads for J55 brakes are made by a company in Canada. They are available at many places . Amazon has them also. I got mine at PEP Boys.
    "PRO STOP CERAMIC" # PR 1331-C
  7. #6
    Dec 2012
    Las Vegas NV
    12
    Thanks for all the info
  8. #7
    RAB's Avatar
    RAB is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS Premium AWD Sport Sedan w/FE5 - RadiantSilver|Ebony
    Jun 2007
    Ontario, Canada
    2,108
    Quote Originally Posted by arw1510 View Post
    arw1510 - note that your 2012 3.6 DI AWD is not equipped with 'J55' heavy duty brakes. The fact that your vehicle is equipped with AWD automatically means that the brake system applied to your '12 CTS is the standard 'JE5' system, which puts ceramic pads front and rear, right from the factory. You can easily confirm your brake system type by having a look at the RPO summary sticker attached to the underside of the spare tire compartment cover.
  9. #8
    Oct 2008
    1,229
    Quote Originally Posted by RAB
    Note that it in fact does have the j55 brakes. Whose car is it? Would you like a picture of my rpo sticker?
  10. #9
    RAB's Avatar
    Jun 2007
    Ontario, Canada
    2,108
    Apologies arw1510. No, don't need a photo of your rpo sticker, but thanks for offering mate. Looking at the GM Online Order Guide I've only now discovered you can have J55 performance brakes combined with AWD on the 2012 CTS Sport Wagon, but not on the Sport Sedan. It's gathered then you own a '12 Sport Wagon. My 2011 CTS Premium 3.6 DI AWD Sport Sedan is equipped with JE5 standard brakes.
  11. #10
    Oct 2008
    1,229
    Nope. Sports sedan
  12. #11
    Sep 2007
    Wilmington, NC
    13,969
    PM me your VIN ... (or post it here) ... i'll check on the pads for you and see if there are any ceramics available
  13. #12
    cawengr's Avatar
    cawengr is online now Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Performance Coupe -3.6 DI 6 Speed Manual
    Apr 2005
    Oak Lawn Il.
    322
    I have a 2011 Coupe with the J55 brake option. I replaced the fronts with Pep Boys PROSTOP PR1331C Ceramic Pads.
    Best thing I have done, no more Black brake dust. Stopping power is about the same.
    I would not go back to semi metallic pads.
    I don't k ow if the 2012 is the same but I would assume it should be.
  14. #13
    dreiloft's Avatar
    dreiloft is offline Cadillac Owners Fanatic
    Automobile(s): 2014 XTS, 2012 Coupe traded, 2010 CTS 4 Dr traded
    Feb 2012
    Doral, Fl
    325
    Quote Originally Posted by cawengr
    Yes they are the same, terrible brake dust. Tried all the aftermarket products to repel with out any good results.
  15. #14
    Dec 2012
    Las Vegas NV
    12
    Went to Pep Boys yesterday and they did not show that particular brake. Since 3 of you have named the same PROSTOP PR1331C brake with good results I will go back and check again. Thanks
  16. #15
    RAB's Avatar
    Jun 2007
    Ontario, Canada
    2,108
    Nope. Sports sedan
    Hmm, interesting - this has me curious. The '12 (and '13) GM Online Order Ref Guide is evidently incorrect. I've sent you a PM. Can you please email a photo of your rpo sticker - I want to have a look at all the rpo codes that make up your '12 CTS Sport Sedan. Thanks.
  • You may not post replies
