Negative terminal on coupe
Results 1 to 3 of 3
2008-2013 Cadillac CTS General Discussion Discussion, Negative terminal on coupe in Cadillac CTS Second Generation Forum - 2008-2013; I'm trying to find the negative terminal on my 2012 3.6 coupe for jump starting. The positive is where the ...
    rchern is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Crystal Red CTS Coupe with Ebony Interior
    Dec 2006
    Mount Kisco,NY
    448
    I'm trying to find the negative terminal on my 2012 3.6 coupe for jump starting. The positive is where the manual shows it but where the manual shows the negative theres no ground. The manual shows a place on the passenger side about 12" back from the positive with a wire connected to it. On my car in that location there are two approximately 1/4" by 1 1/4" threaded studs that are painted (not a good ground) with nothing attached to them and what looks like a 1/4" threaded female connection with nothing in it. There's also the head of what looks like a 1/2'' bolt unpainted. I don't have to jump my car now but I just happened to be looking for the way to jump it. Anyone have any info? Thanks in advance.
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Re: Negative terminal on coupe
    As for a negative ground; I have always just attached the jumper cable to the block.
    gohawks63's Avatar
    gohawks63 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Black Diamond CTS-V Coupe
    Feb 2008
    53
    3,342
    Quote Originally Posted by C "T" ess
    Or a bolt in the engine compartment. I believe there are a couple near the positive terminal.
