Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: Axe's attempt at thermal vision system for CTS-V
    cadillaxe's Avatar
    cadillaxe is offline Cadillac Owners Fanatic
    Automobile(s): '13ctsvcp,'10bmwS1KRR,'13YCCchopper
    Jun 2012
    san antonio, tx
    363
    Yesterday my FLIR Pathfinder LE system arrived. It's a thermal imaging system, here's a vid .
    Ideally, I'll have this mounted and displaying on the factory nav screen before i drive to CO at the end of June.
    Anyone have any experience doing this? I'm going back to the dealer Monday to talk to the wiring guy and see if i can get a schematic for the car so i can try to make this a clean install and minimize the chance of F'ups.
    First thing i'll have to decide is where to mount it. i hate putting it in front of cooling radiators. there's a duct right by the fog lights, but i believe (have to check) those are functional for brake cooling. not exactly easy getting behind the grill in the first place. Lots of cussing awaits me, raining so can't ride the chopper anyway, might as well start looking this thing over. any tips from experience are appreciated.
    OMG's Avatar
    OMG is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 3.6DI
    Mar 2013
    Northern IL Suburbs
    30
    231
    Re: Axe's attempt at thermal vision system for CTS-V
    Badass. I want one. I'd proably would just mount it on the sunvisor like the video cause then I would just flip it down when I need to use it. (I'm short) Let us know how it goes!
    cadillaxe's Avatar
    Jun 2012
    san antonio, tx
    363
    if i can't figure out the wiring into the screen before the CO trip, that's where mine will be for the time being.
  5. #4
    cadillaxe's Avatar
    Jun 2012
    san antonio, tx
    363
    used a battery charger to make sure everything functioned. started taking things apart. i had to modify the mounting case, but i think i found a location that won't block much airflow and will allow good vision. just need to make another bracket and get everything wedged in properly. also got a wiring diagram for the backup camera today, so hopefully that helps me figure out the dash spaghetti...
    here's some test images of the car in the garage, Sunshine, and Baron.
  6. #5
    HurstGN is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,736
    Quote Originally Posted by cadillaxe View Post
    How about sharing that diagram
  7. #6
    cadillaxe's Avatar
    Jun 2012
    san antonio, tx
    363
    i can try to scan in a jpeg of it, but what i'm realizing is it's not going to do me much good. it's just what comes out of the backup camera, but as opposed to splicing in there, i'll likely have to catch the vid signal from the head unit to the monitor, as who knows where the reverse trigger is to override the radio vid signal, etc. i'll post more as i figure all this out...slowly...
    Sunshine leaves for Europe tomorrow, so was hoping to get a lot done this weekend, but Chip bought an early m5 bmw that roached the timing chain tensioners, so starting tomorrow eve i'll be in his garage repairing that gem...
  8. #7
    cadillaxe's Avatar
    Jun 2012
    san antonio, tx
    363
    Today i got the bracket basically made and made sure the grill doesn't interfere with the camera view. took more hours than i want to admit to make the bracket, and no, it's far from perfect, but it's crude yet effective like me, and with coat of black paint, it'll be just fine hiding under the trim panels under the hood. just have to get it out on a long straight road and get the adjustments right, then start trying to hook it up to the nav panel. i've got a couple more pigtails coming from the visions system supplier Wednesday, so hopefully i have things pretty figured out by then...
    pics below show the cam hanging from the bracket i made. other is a test view. you can see the cam behind the grill on the left, then my thermal shot on the test monitor.
  9. #8
    cadillaxe's Avatar
    Jun 2012
    san antonio, tx
    363
    i hate wiring, but part of the job...
  10. #9
    cadillaxe's Avatar
    Jun 2012
    san antonio, tx
    363
    fortunately i found one prototype box on a shelf somewhere that does exactly what i need, allows external camera input. Yesterday i got the screen to actually display the thermal camera, so now i just have to get the camera mounted solid, run cabling, final connections, and put everything back together properly.
  11. #10
    cadillaxe's Avatar
    Jun 2012
    san antonio, tx
    363
    Finally got everything working and back together clean. didn't have to cut into any wiring or mount any switches in the console. just hit mute 4 times to activate dash menu, use the up/down to scroll, and right mirror to toggle. works like a champ!
  12. #11
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Perhaps I'm naive but what exactly are you trying to accomplish; in other words, how will this accessory serve you. I've never seen anything like this other than in cop shows. I'm sure there is a reason you want it, I'm just curious as to what that is. thanks
  13. #12
    jeffc83's Avatar
    jeffc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS4 DI Premium (SOLD) / 2013 XTS Luxury (TOTALLED) / 2015 BMW 328i XDrive Lux
    Feb 2012
    Southeastern PA
    1,957
    I believe one of the major benefits is the fact he can now see pedestrians/animals at night when his lights may not do the job (especially on the sides if they're walking toward the street)...I've been impressed with what these systems can do. (Although I don't see a need for it myself)
  14. #13
    hauler's Avatar
    hauler is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 Sportwagon 18.2city 28hwy 25hwy AC on
    Nov 2012
    Moline,IL
    531
    I like it. IMO everyone needs a hobby. Axe has one at least 2 levels above mine.
  15. #14
    Oct 2012
    12
    Wow!!!!
  16. #15
    jeffc83's Avatar
    Feb 2012
    Southeastern PA
    1,957
    Quote Originally Posted by hauler
    And four levels above mine...lol
  • You may not post replies
