AC Freon do it yourself kit
Results 1 to 4 of 4
Like Tree1Likes
  • 2 Post By rspreng
2008-2013 Cadillac CTS General Discussion Discussion, AC Freon do it yourself kit in Cadillac CTS Second Generation Forum - 2008-2013; Has anyone tried using AC freon do it yourself kit? Uses R134a....
    danoh123's Avatar
    danoh123 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS 3.6 Premium AWD
    Sep 2012
    Boston area
    167
    71MonteCarlo is offline Cadillac Owners Member
    Automobile(s): 2012 CTS Coupe
    Aug 2011
    Killeen TX
    75
    69
    Re: AC Freon do it yourself kit
    You need to locate your leak so you don't have to continue adding R-134. Often it is the Schrader valve itself. Check both the high and low pressure valve after adding just one can of refrigerant.
    rspreng is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Sedan RWD Radiant Silver|Ebony
    Jul 2006
    Knoxville TN
    41
    231
    You need to have the system checked for leaks. If the system is not cooling well because of a leak it needs to be fixed first. As for the DIY can kit with hose and half azz gauge, it's not worth it. I ALWAYS charge with a proper manifold gauge set and pull a vac on my lines before I open the valves at the shader valves or quick connect fittings. Read your pressures and compare to outside ambient temps. With both high and low pressures you can check for problems with compressor, orfice, restriction and etc. I am very particular when it comes to AC repair. It's not hard but you have to have the right stuff to do properly.
    MoFex and MoFex like this.
    Michael_atDell's Avatar
    Michael_atDell is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS 3.6L DI AWD
    May 2011
    Austin, TX
    37
    404
    Try a can, I've used them twice. Seems the R134a leaks out over the Winter. I've checked for leaks and nada...
  7. Remove Advertisements
