Shift Indicator in Sport Mode ('13 vs '09)
Results 1 to 12 of 12
2008-2013 Cadillac CTS General Discussion Discussion, Shift Indicator in Sport Mode ('13 vs '09) in Cadillac CTS Second Generation Forum - 2008-2013; OK, I took my 09 CTS in for service Friday and got a '13 base CTS for a loaner for ...
    HurstGN is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,541
    QuestionShift Indicator in Sport Mode ('13 vs '09)
    OK, I took my 09 CTS in for service Friday and got a '13 base CTS for a loaner for the day. When driving it, I noticed that in the '13 CTS, when putting the trans into Sport Mode (just move the shifter to the right but DO NOT shift using the shifter), in the '13, the dash indicator showed the gear changes from 1 through 6 as I drove. In my '09, this gear indicator only works when in Manual Mode (shifter to the right and manually shifting by moving the shifter forward or backwards).
    1) Is this normal for the '09 to NOT show the gear in Sport Mode?
    2) If #1 is yes, is there a software update that can be applied to the '09 to make this work like the '13?
    I really liked seeing the gear indicator change, I don't know why, but I liked seeing it, and would like to see it in the '09 if at all possible.
    Thanks,
    Dan
    somedaycts is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Cadillac CTS4
    Jan 2010
    Michigan
    394
    Re: Shift Indicator in Sport Mode ('13 vs '09)
    (1) Yes. 08-09 do not show gear number when in Sport mode. They only show when in Manual mode.
    (2) M.Y. 10+ has this feature. Not sure if 08-09 can receive software update for this.
    Tbbt is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,125
    Same here with my 2010. IMHO it's a great feature, hope you find out how to enable this in 2008-2009.
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    I believe it happened when the paddle shifters became available. This way you can choose your gear. Even in full automatic mode if I tap the paddle it will immediately shift and show the gear selected. a few seconds later if no other shifting is done it returns to full automatic with no gear selection shown. Since other have tried to retrofit paddles to 08-09's without success I think there is no way to retro fit.
    gohawks63's Avatar
    gohawks63 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Black Diamond CTS-V Coupe
    Feb 2008
    53
    3,342
    Quote Originally Posted by C "T" ess
    The feature is available whether or not you have paddle shifters.
    My '12 premium coupe does not have the paddle shifters, but I still have the gear displayed in sport mode.
    Mistercoffee2's Avatar
    Mistercoffee2 is offline Cadillac Owners Enthusiast
    Mar 2012
    Houston TX
    516
    Quote Originally Posted by C "T" ess View Post
    I have retrofitted the steering wheel mounted shift switches (paddles were never offered by GM) to my 08. Very simple process.
    Cost about $100. Requires steering wheel removal, must have some skill with hand tools and soldering.
    They work when the shift lever is in sport mode. Display works same as shifting with lever.
    json3144's Avatar
    json3144 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS4 Coupe Black Ice
    Jan 2011
    St Louis MO
    35
    83
    Quote Originally Posted by Mistercoffee2
    I'd love to see the finished product!
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,773
    I guess I'm wrong. Must have been a senior moment that lasted all day long
    Mar 2012
    Houston TX
    516
    Quote Originally Posted by json3144 View Post
    Not much to see after the wheel is mounted. Here is a photo before mounting.
    dekes1 is offline Cadillac Owners Member
    Automobile(s): none
    Jan 2010
    44
    17
    Mistercoffee2 , it would be much appreciated if you could write up a summary of how you retrofit the wheel to your 08. Specifically, I'd be indebted if you could outline the wiring circuits you modified. Thanks!
    Mar 2012
    Houston TX
    516
    Yes I will. Long overdue. But first let me be very clear. In this threat, and others, I said that I have retrofitted the steering wheel shift buttons to my 2008 CTS. That is true and they function exactly as the shifter lever does. But there was a lot of talk about the functions for the instrument panel gear indicator on different year models and that does not change with my mod. That must be a change in the BCM software in later models. What it does with the shift lever it will do with the buttons.
    I need to do this write up because it is a relatively simple mod, not expensive and lots of fun.
    Coming soon, as in this week, I promise. EDIT: OOPS, out of town through next week 6/7.
    jeffc83's Avatar
    jeffc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS4 DI Premium (SOLD) / 2013 XTS Luxury (TOTALLED) / 2015 BMW 328i XDrive Lux
    Feb 2012
    Southeastern PA
    1,956
    Thanks! I may be interested myself as I "tinker" way too much
  15. Remove Advertisements
