premium gasolene - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 55
Like Tree1Likes
2008-2013 Cadillac CTS General Discussion Discussion, premium gasolene in Cadillac CTS Second Generation Forum - 2008-2013; Apparently GM thought one was necessary for the 2014 Z28...
  1. #31
    CTSCHICK Guest
    Re: premium gasolene
  2. #32
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    the 1993-2011 run of NorthStar engines had a CAI also ... just wasn't really fancy lookin'
  3. #33
    gohawks63's Avatar
    gohawks63 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Black Diamond CTS-V Coupe
    Feb 2008
    54
    3,342
    Quote Originally Posted by CTSCHICK
    No one is saying that it isn't necessary or does not add any value. In your example, the car was designed to take advantage of the CAI. The same goes for the Mustang Shelby Cobras that come with a CAI from the factory.
    What we're saying is that swapping out the stock air box for a CAI without reprogramming the engine management system to take advantage of the increased air flow will yield minimal, if any benefits.
  5. #34
    CTSCHICK Guest
    Quote Originally Posted by gohawks63 View Post
    Like I said GM made kits available through GMPP for cobalts, G5, Soltice, Sky that did not require a reflash or reprogram to compensate for the kits yet provided gains.
    The only kits for Gm Cars that I have seen that specifically state tuning is required in order to use the kit has been Vararam but they also offer none tune required kits and those kits are the only ones I have seen requiring a tune after install.
  6. #35
    gohawks63's Avatar
    Feb 2008
    54
    3,342
    A Cold Air Intake, as the name implies, is supposed to direct colder, denser air into the engine that is supposed to offer more power. Things such as placement of the inlet, whether it is sufficiently distanced from engine heat, the tubing material and the amount of bends in the tubing all are factors on the effectiveness of a CAI, especially one that doesn't require a tune.
    The tubing material I have read is a bigger factor than you might think. Many people go for the CAIs that have the polished metal tubes because of the appearance. The reality is that metal tubes tend to retain heat and in actuality those systems with a plastic tubing do a better job of delivering "cold" air. As cold as you can get under the hood.
    Since the MAF sensor really controls how much air is sucked into the engine, I would imagine that the "tuneless" CAIs deliver whatever power that they do because of the colder air they deliver.
  7. #36
    EVH5150's Avatar
    EVH5150 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Coupe Premium: RWD, FE3 Suspension, 6-speed manual
    Apr 2013
    Somewhere in Canada LOL!!!
    38
    321
    Quote Originally Posted by OMG View Post
    All those things are were around long long before F&F. lol
    Ha ha LOL!
    I know that, but it seems as though it really took off after that movie especially with the ricer/tuner crowd LOL!
  8. #37
    WRXtranceformed is offline Cadillac Owners Fanatic
    Oct 2011
    135
    Quote Originally Posted by GM Tech NY View Post
    and then i see some articles on people removing what they are calling a resonator from the intake box, this has to be the DUMBEST thing I have ever seen done to a car if ANYTHING your confusing the ECM and LOSING performance. not gaining crap.
    If you are referring to a DIY post I put up in the performance section, you might want to read through the entire post to see that I mentioned that there was absolutely zero performance gain or loss. That mod wasn't meant for a performance gain. It is meant to add a little more noise when you hit the go pedal. You might have been a tech but you're definitely not an engineer. Intake silencers / snorkuses / resonators are just that. With the ram air/resonator removed, the air in an otherwise stock CTS is still being pulled in from the same square hole in the same intake box and going through the same filter and hitting the same sensors. Hence there is no performance gain or loss.
    Just so I don't muck up this thread like everyone else rabbit-trailing on intakes and exhausts, on a stock CTS you are not going to notice a bit of difference running higher octane fuel. The only exception to that is if you are running a Trifecta tune as confirmed by BNR, since those tunes were optimized for 93 octane (they still run fine on 87). I personally wouldn't worry about running "top tier" gas in a non-forced injection car. If you are worried about keeping the fuel system clean, buy a $6.00 bottle of Seafoam and dump it in your gas tank every couple of months or so.
  9. #38
    Sep 2007
    Wilmington, NC
    13,986
    Stay away from the seafoam and use techron instead. Theres even a gm branded version available at your dealer. No more often than once every 5000 miles ... Truthfully it should only be used if needed (or there's reason to believe it might be needed).
  10. #39
    JackB is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS AWD DI 2014 AWD CTS DI
    Oct 2004
    510
    In other discussions on this forum there were statements made that Techron is a waste of money in a DI engine. Would be interested to hear any comments to the contrary.
  11. #40
    gohawks63's Avatar
    Feb 2008
    54
    3,342
    Quote Originally Posted by JackB
    Techron will still help to keep the injectors clean, but it will have no effect on the intake valves.
  12. #41
    MoFex's Avatar
    MoFex is offline Cadillac Owners Connoisseur
    Automobile(s): 08 White Diamond CTS DI RWD FE2 all options
    Oct 2007
    metro Atlanta
    60
    2,541
    Exactly!
  13. #42
    OMG's Avatar
    OMG
    OMG is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 3.6DI
    Mar 2013
    Northern IL Suburbs
    30
    231
    Seafoam is the only thing that works on the intake valves but it is more preventive has to be from new and done every oil change. There was much speculation whether it would work because of the mixed results. But a member on the Cobalt SS Turbo forums (which have the same Carbon build up on the valves as we do) seafoamed his CBSS every oil change and took pics at 60k mi and it look damn good.
  14. #43
    Sep 2007
    Wilmington, NC
    13,986
    How is seafoam going to 'work' on the intake valves when it is directly injected into the combustion chamber?
    you know it's basically just lacquer/paint thinner, right?
  15. #44
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    I think one thing that should be understood is the fact that modifications to intake and exhaust will be compensated for by the ECM. Unless you change the control module for a more aggressive set up, all you are doing is confusing the ECM as it tries to keep all of these factors with in the parameters of the factory settings. You may add additional seat of the pants feel but you may likely loose mpg's.
  16. #45
    CTSCHICK Guest
    Except the Maf doesn't control or regulate the amount of air or temperature of the air entering the engine since the Intake air temperature sensor is built into the Maf it only reads the amount of air entering and the temperature of that air and then sends it to the PCM so that the PCM can make the proper adjustments to compensate for those readings.
    It is not different than how the engine is able to run properly during the change of weather temperatures during the seasons and changes in elevation with help of the Map sensor.
    *Edit and about the tune required version's of the Vararam kits that I mentioned previously I asked my b.f. about why the tune versions require a tune he said it is because they change the diameter of the MAF housing to a larger size to accept more air for those version's and since the factory calibration is based off of the stock diameter housing the MAF tables have to be readjusted to compensate for the larger housing and that is the only reason.
    The None tune version is the same intake kit with a stock sized Maf housing so no tune required
    Quote Originally Posted by JackB View Post
    Besides keeping the injectors clean Techron Concentrate Plus has an additive that will clean and supposedly put a protective film over the fuel pump sending unit wiper board that is used for your fuel tank level readings.
    For some reason that I forget the GM's are more susceptible to contamination and the reason why a lot of GM's fuel gauges read inaccurately
  17. Remove Advertisements
