Siezed Discs
Results 1 to 6 of 6
2008-2013 Cadillac CTS General Discussion Discussion, Siezed Discs in Cadillac CTS Second Generation Forum - 2008-2013; I'm trying to get my front discs off my 2011 CTS and they are not cooperating. I am reluctant to ...
    RRIXX is offline Cadillac Owners Member
    Apr 2013
    9
    Siezed Discs
    I'm trying to get my front discs off my 2011 CTS and they are not cooperating. I am reluctant to use a 5 pound hammer so I have been using a rubber mallet try to loosen them but to avail. Any suggestions?
    99flhr is offline Cadillac Owners Enthusiast
    Automobile(s): CTS
    Jul 2012
    N.E. OH
    722
    Re: Siezed Discs
    1. spray with penetrating oil
    2. install lug nuts
    3. hit the corner of the "hat" area with hammer. ( 3lb "work hammer" preferred)
    This yeilds far better results than hitting the disc from the backside
    worlda's Avatar
    worlda is offline Cadillac Owners Member
    Automobile(s): Cadillac2008 CTS and 2013 XTS
    Dec 2006
    CT
    56
    29
    Re: Siezed Discs
    There is a lock pin on the rotor did you undo it it in the mid of the rotor GM put it on to line up the rotor
    Charlie
    OMG's Avatar
    OMG
    OMG is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 3.6DI
    Mar 2013
    Northern IL Suburbs
    30
    231
    Re: Siezed Discs
    99flhr pretty much sums it up.
    I use PB blaster and taps on the hat to break as much rust loose as I can. Let the PB work for about 15 mins while I work on the other rotors then I tab the back of the rotor but from the INSIDE of the edge of the rotor to try to pop it out as straight as possible.
    Method has worked for me for years on 50+ brake changes I've done.
    Only vehicle we couldn't get off was my sister's H3 which didn't get changed until 90k mi. After 2 hrs my dad ended up just cutting the rotor hat off.
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Re: Siezed Discs
    be sure to use plenty of brake clean spray if you plan on using that disc again.
    Apr 2013
    9
    Re: Siezed Discs
    Quote Originally Posted by worlda View Post
    Charlie
    Yes, I had done that already. I was able to get them off by hitting the 'hat' of the disc with a 3 pound hammer. Thanks for your all your help. All is good.
  9. Remove Advertisements
